wifes ACCORD (5th Gen)
Old Nov 2, 2003 | 07:59 PM
RUBZERK's Avatar
Default wifes ACCORD (5th Gen)
My wife has been telling me for the past few days that her car makes a rattle noise.
So I take it for a spin & I hear like the exhaust rattle at 2000rpm.
Could it be the heat shield ???
Or could it be something else ?
The noise starts at 2000rpm but as i give it more gas it goes away.
Its a 96 accord lx auto with 52,000miles
Old Nov 2, 2003 | 08:15 PM
97F22B2's Avatar
Default Re: wifes ACCORD (RUBZERK)
take it to an exhaust shop and have them look at it or just jack the car up and check for lose heat sheilds or possible broken exhaust hanger.
Old Nov 2, 2003 | 08:26 PM
NathanMorris's Avatar
Default Re: wifes ACCORD (97F22B2)
it's the heatshield over the catalytic convertor I'd put money on it.....it's a VERY common problem with 5th gens, and from what I've heard anyway, it's really hard to get "permenately" fixed. The best idea is probably just to remove the heatshield on the bottom side, and just don't park on any high grass.
- Nathan
Old Nov 2, 2003 | 08:36 PM
RUBZERK's Avatar
Default Re: wifes ACCORD (92Lx)
Cant i just replace the bolts & leave it on ???
Old Nov 3, 2003 | 07:12 AM
1DOC422's Avatar
i had the same problem with the cat cover..the holes where one of the screws go melted so i just took it off
Old Nov 3, 2003 | 08:09 AM
iam7head's Avatar
Default Re: wifes ACCORD (1DOC422)
there's a oem buzz kit for heat shield also
Old Nov 3, 2003 | 08:38 AM
RUBZERK's Avatar
Default Re: wifes ACCORD (iam7head)
WHAT THE HECK IS THAT?
Old Nov 3, 2003 | 08:42 AM
iam7head's Avatar
oem buzz kit is used with the bad oem heat shield to basically stop the buzzing, i dont have one on my car but I think it's nothing more than a bunch of rubber washer or rings
Old Nov 3, 2003 | 08:44 AM
RUBZERK's Avatar
WHERE DO I FIND THIS AT?
Old Nov 3, 2003 | 08:47 AM
iam7head's Avatar
try to get the car to the dealer, some dealer might give it to you for free, again, i have no experience with this so dont qoute me on this.
but i remember some guy here wrote something about the buzz kit
Old Nov 3, 2003 | 12:09 PM
97F22B2's Avatar
cut out the cat and put in a test pipe
Old Nov 3, 2003 | 02:49 PM
mwkirchner's Avatar
The problem you are describing was addressed by Honda. There is a bulletin and the number is 94-041 and it was originally released on May 13, 1996. It explains about the buzz and the replacement of the gaskets and bolts before and after the mid-pipe (the pipe after the "A" pipe and before the convertor.
The part number for the kit you will need is 18010-SV4-305 and it contains two gaskets, four flange bolts, four springs, and four self-locking nuts.
We have had some luck at work by taking the joint apart and putting some Moly grease on it so it can slide better. Most times it has quieted it down ... other times we had to actually change the gasket and put the new bolt / spring kit on the car.
Old Nov 3, 2003 | 03:55 PM
azian21485's Avatar
Default Re: (mwkirchner)
you can just use those metal plumber ties or hose ties and wrap it around the heat shield..works wonders
Old Nov 3, 2003 | 11:26 PM
RUBZERK's Avatar
Default Re: (azian21485)
I just got some stainless steel hose clamps from my job.
Im just gonna try this first
Old Nov 4, 2003 | 10:24 AM
RUBZERK's Avatar
Default Re: (RUBZERK)
Well heres what I did.
I put the car up on ramps & got underneith & shook everything that looked like would make the noise.
I noticed that the bolt tabs that the heat shield bolts to the upper heat shield were rusted from heat & moisture. (snapped)
So to fix this i used 2 100% stainless steel clamps & put them around the outside of the heat shields to hold them firmly in place.
I took the car on a 30 min drive to see if I could get it to make the noise &
NO NOISE
Now I know some of you guys will say that they will just rust anyway, but at least my wife wont hound me anymore
The Black Pearl
Feb 14, 2010 10:13 AM
DroCity
Jul 28, 2007 09:51 PM
raceboy71
Mar 26, 2005 08:25 PM
CiBBeasT
Aug 19, 2004 04:01 PM
skim19104
Aug 1, 2004 03:54 PM
