clicking noise = axle going bad?
Old Sep 6, 2001 | 07:37 PM
97BB6's Avatar
New User
Default clicking noise = axle going bad?
I noticed today that a clicking noise was being emitted from the passenger side front. I'm sure it is coming from the wheel because the clicking noise is speed dependent. Is this a symtom of my axle going bad? The car only has 40k miles. Someone help me please, its annoying the hell out of me when the windows are down.
Old Sep 6, 2001 | 10:55 PM
owen_the_soyboy's Avatar
Default Re: clicking noise = axle going bad? (97BB6)
if it gets worse when you are coasting, it will be a case of loose lugnutz.
if it gets worse under acceleration or hard braking, it can / may be a bad wheel bearing/hub.
if it gets worse only with tight cornering at any speed, low speed especially, it may be a CV joint.
HTH
Old Sep 7, 2001 | 07:05 AM
keithv's Avatar
Default Re: clicking noise = axle going bad? (owkone)
Loosen and re-torque the lug nuts to spec.s, 85ft.lbs. Adjust the tire pressure to specs. If that does not help, rotate the tires, and see of the noise moves. If it does then it is the wheel. Check the hub cap if you have one, it sometimes clicks.
I've always heard 80 ft-lbs on the lugnuts. I doubt the 5 ft-lbs would make a difference, just putting (what I think is the right info) out there.
Old Sep 7, 2001 | 05:29 PM
97BB6's Avatar
New User
I took a look at the wheel today and found out it was a stupid nail making the noise. Good thing it isn't the bearing or an expensive part going, can't afford it right now.
WRTEG
Aug 18, 2004 02:15 PM
tuan...
Aug 2, 2004 06:31 AM
es_squared
Jun 5, 2004 09:00 AM
BLK99VTECR
Nov 10, 2003 01:16 PM
REDBARON
14
May 24, 2001 07:25 PM
