got one for u tech guys
Old Nov 2, 2003 | 12:42 PM
krazie1's Avatar
BANNED
Default got one for u tech guys
here is my question currently breaking in my beast and she won't go passed 6500 rpm's without notcing and hearing loss in power
what can this be
ecu chipped and well i am thinking maybe timing adjustment???
what can it be I try to take it slowly or at least half throttle and she won't ge passed with out hearing just motor noise and no go
can u guys help what it could be
Old Nov 2, 2003 | 12:57 PM
hybridEj6's Avatar
Default Re: got one for u tech guys (krazie1)
your breaking it in and your going over 6500rpm?
Old Nov 2, 2003 | 01:17 PM
krazie1's Avatar
BANNED
Default Re: got one for u tech guys (ekhybrd)
well i am at 700 miles already so u know
it is possible already
but still i don't know why i am getting this problem
Old Nov 2, 2003 | 01:26 PM
hybridEj6's Avatar
why dont you take it to the dyno and get the cam gears tuned...i dont recoment tuning them on the street. whats the distributor timing at?
whats your set up/car?
Old Nov 2, 2003 | 01:33 PM
krazie1's Avatar
BANNED
well the cams yes they will be set at the time of dyno tuning
and well my distrubor is set to stock
but got a feel's chip in my ecu so it might be off
but when i add it stock the motor it ran fine on the chipp with stock timing...
anything else it could be
and if u like to know my set up check the 2.0 setup's i listed mine i think i am the last one right now....
Old Nov 2, 2003 | 01:54 PM
hybridEj6's Avatar
you should go to the dyno....what kind of cams?....you might be leaning out on top end...what do the plugs look like?.....have you done a compression check? Most chipped ecu advance the timing on vtec and supply more fuel....but i dont really like chipped ecu's because every motor is different.....go v-afc or even better hondata....and most importantly get that ****** on the dyno and let us know what pull
Old Nov 2, 2003 | 06:04 PM
krazie1's Avatar
BANNED
i have a vafc and well like i said it ran fine before but now with the JE pistons it runs like this???
and yeah i will take to the dyno as soon as i am done breaking it in which is another 500 miles or so
and the cams i am running are custom settings like spoon or skunk 2 stage 3's...
Old Nov 2, 2003 | 06:05 PM
krazie1's Avatar
BANNED
the plugs look fine regular wear
and the compression is fine also
Old Nov 2, 2003 | 06:07 PM
hybridEj6's Avatar
your vafc will have to be re tuned with the chipped ecu
Old Nov 2, 2003 | 06:09 PM
hybridEj6's Avatar
were you going to get it tuned...you should go to trackmasters...it near where you live...im shure you have heard of them
Old Nov 2, 2003 | 06:28 PM
krazie1's Avatar
BANNED
yeah there is a idea but i rather go to autolink
they have hooked me up even more then my own friend at his shop....
so i trust them and well if not there is always erick's racing where i got my throttle body from he owes a favor in about 500 miles though
if that is the problem u know
turbochargeb18c
Aug 1, 2005 09:44 AM
Modifiedinteg
Oct 25, 2003 11:34 PM
smkngsr
Nov 8, 2002 07:20 AM
hoya_10fintec
Sep 13, 2002 11:37 AM
