these dudes!!!!
Old Sep 6, 2001 | 05:06 PM
B18C-RnVA's Avatar
New User
Default these dudes!!!!
So today the tranny shop bought my car back, and guess what?? These cats were driving my car!!! Yep my wife was home when they bought it here and she said that they pulled it off the tow, started it up. put it in reverse and then in 1st and pulled it forward inthe parking spot. Im like what the hell. SO when i get home from work i hop into the car and now it grinds in reverse but it stays in gear. I dont know what the hell is wrong. Im still saying shift linkage and gear oil though. what do you guys think??
Old Sep 6, 2001 | 05:25 PM
BreakStuff's Avatar
New User
Default Re: these dudes!!!! (B18C-RnVA)
Please don't tell me you put gear oil in your tranny....
Old Sep 6, 2001 | 05:34 PM
B18C-RnVA's Avatar
New User
Default Re: these dudes!!!! (BreakStuff)
nope i didnt put anything in the tranny. what do you think it is breakstuff, or anybody. I hope i dont need another tranny. if so i guess ill go with an ls tranny. but i dont think its the tranny.
[Modified by B18C-RnVA, 2:34 AM 9/7/2001]
Old Sep 7, 2001 | 08:07 AM
B18C-RnVA's Avatar
New User
anyone want to take a shot at this
Old Sep 7, 2001 | 08:26 AM
Jared's Avatar
im me an explanation of the entire problem
Old Sep 7, 2001 | 12:03 PM
B18C-RnVA's Avatar
New User
Default Re: these dudes!!!! (Jared)
jared did you get the IM i sent you
Old Sep 7, 2001 | 04:03 PM
nugget8000's Avatar
New User
I tell you, check the clutch pedal. If you can modulate the clutch (don't push it all the way to the floor but instead somewhere in between) and get it into/out of gear, then it is likely the height adjustment on the clutch. Easy thing to check, easy thing to fix. Hope this helps.
Old Sep 7, 2001 | 04:15 PM
B18C-RnVA's Avatar
New User
Default Re: these dudes!!!! (nugget8000)
How can i fix this nugget can you give me some guidance on it. or anybody
Old Sep 7, 2001 | 04:27 PM
B18C-RnVA's Avatar
New User
man i just went to the car and now that **** will shift to first with no clutch and reverse with no clutch, but wont shift to any other one when i push in the clutch!!! Aint that some ****??? im just going to take back to the tranny shop and fork over 1400 dollars when i get it. so my baby gonna be still at least until the end of the month.
Old Sep 7, 2001 | 04:31 PM
nugget8000's Avatar
New User
First check out whether or not what I posted above is true. Remember to MODULATE the clutch (try it at different positions). If it just doesn't work at all, then I doubt it would be the clutch adjustment. I gave some instructions for this here https://honda-tech.com/zerothread?id=64995 . Any questions just ask.
[Modified by nugget8000, 1:32 AM 9/8/2001]
[Modified by nugget8000, 1:34 AM 9/8/2001]
Old Sep 7, 2001 | 05:22 PM
B18C-RnVA's Avatar
New User
man i dont know what the hell is up with this car....
tonight im outside with my boy showing him the problems i have with the car, and this time the car goes from 1st-reverse with the clutch in the problem that popped up tonight is that the reverse gear will not engaged or something. when i go into reverse the gear just grinds when i give it gas and the car just rolls. the reverse lights dont even come on. I think i just need to get a new tranny and gear set up. Or maybe just new gears and shiftlikage. Also a hydro clutch doesnt use a cable does it??
Old Sep 8, 2001 | 07:09 PM
stick's Avatar
tony,
call my friend at hall mitsubishi/acura. good mechanic
his name is bob case 631 5586.
tell ur situation and tell him i sent you
and he can get u brand New OEM tranny
get that **** fixed yo
Old Sep 9, 2001 | 08:48 AM
B18C-RnVA's Avatar
New User
Default Re: these dudes!!!! (stick)
thanks stick im going to call him on Monday
cfrank89
21
Nov 27, 2011 05:42 AM
nickohlassss
Apr 13, 2009 05:43 PM
xpsonic
Sep 26, 2004 09:48 AM
crx_88_si
Jul 27, 2004 08:32 AM
joeyandhiscrx
11
Jan 7, 2004 03:53 AM
