Why do people mount batteries in the trunks\hatches on FWD Drag Cars?
Other than underhood space, thats the only reason...
If it's a road race car, you can say it's for the sake of weight dist.\corner weighting. I don't see why people do this otherwise...I see it on alot of street cars that have no business doing it. Ideal place would be strapped to the front bumper...
Suprdave
Suprdave
ummm because they wanna be cool like the pros? Cause they think that if someone sees that they will assume the car is fast and not wanna race em..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE »</TD></TR><TR><TD CLASS="quote">i would do it for theft prevention. if they cant get to your battery by popping your hood open, then they cant disarm your alarm or horns.</TD></TR></TABLE>
all they would have to do is cut the positive cable from the starter..the battery always has to connect there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE »</TD></TR><TR><TD CLASS="quote">Its JDM...Didnt you know Dave</TD></TR></TABLE>
Werd...
Werd...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller »</TD></TR><TR><TD CLASS="quote">idk but id leave it in the front so i get more weight and better traction</TD></TR></TABLE>
space is the ONLY reason I could ever think of not putting it there
the ONLY reason that I have considered moving my battery to the rear of the car is, so that I can wire up my master cutoff without all of the extra cable that will have to run to the front of the car...
i vote for space in the engine bay , mine was pretty tight until i started just randomly taking out overrated pieces
the abttery is stil lup front for the time being , i dont see a reall need to do it right now
I think for those with the EF or DA chassis the battery is always in the way and causing unecessary bends in the intake tubing. For my DC chassis, I don't see the point.
i moved mine for the space i need to mount stuff there!!! But now u have to have a cut off switch located at the back of the car to i might move it back to the front!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">I think for those with the EF or DA chassis the battery is always in the way and causing unecessary bends in the intake tubing.</TD></TR></TABLE>
your damn right about that, although this is a good comprimise with those cars----->
Also if the battery is too big for up front. My optima wouldn't fit in the compartment so instead of mounting it on an angle I put it in the trunk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic »</TD></TR><TR><TD CLASS="quote">Also if the battery is too big for up front. My optima wouldn't fit in the compartment so instead of mounting it on an angle I put it in the trunk.</TD></TR></TABLE>
Optima makes a smaller battery now that will fit in the designated factory location.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quickda6 »</TD></TR><TR><TD CLASS="quote">
Did you make that?
</TD></TR></TABLE>Did you make that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">
Did you make that?</TD></TR></TABLE>
no, a friend of mine made it. its made in the shape of a cross, and the bends are perfect. if you would want one, he could bang out another im sure.
