turbo choices for homemade setup
Old Nov 2, 2003 | 06:16 AM
USDMMARK's Avatar
Default turbo choices for homemade setup
ive looked at all three, and im not sure what would be better,
rhb5
t25
14b
my goal is to have a daily driver but to take it to the track every once and a while, most of my driving with the car will be daily though.
i hear the rhb5 spools up quicker then the other two and is set at 8 lbs, which is about where i wanted more then six less then ten on a stock d16a6 block
any extra info on these three would be nice, or if there are any others that are recomended, hopefully i gave you all the info needed for your awnsers
Old Nov 2, 2003 | 08:03 AM
USDMMARK's Avatar
Default Re: turbo choices for homemade setup (Dr.D)
bump
Old Nov 2, 2003 | 11:12 AM
bigwig's Avatar
none of the above. get a T3 .42/.48 but most likely it will run out of steam at the end of your powerband...
Old Nov 2, 2003 | 11:34 AM
NuclearB18B's Avatar
Default Re: (bigwig)
SC61
Old Nov 2, 2003 | 11:52 AM
crxY-49's Avatar
if this is on a d-series daily driver the t25 wouldn't be a bad turbo. i have a 14b on my daily driven d-series.
Old Nov 2, 2003 | 12:06 PM
ITRswapandslow's Avatar
the t3 is the easiest to setup...and it will offer the best performance.
get a .60 T3....and you'll love it. Pretty damn quick spool...and decent top end.
Old Nov 2, 2003 | 01:47 PM
DigitalFusion's Avatar
Default Re: (eh2nboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh2nboost &raquo;</TD></TR><TR><TD CLASS="quote">get a .60 T3....and you'll love it. Pretty damn quick spool...and decent top end.</TD></TR></TABLE>
Old Nov 2, 2003 | 01:56 PM
D A 9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh2nboost &raquo;</TD></TR><TR><TD CLASS="quote">the t3 is the easiest to setup...and it will offer the best performance.
Yep, agreed! that's what I got and I love it
Old Nov 2, 2003 | 04:43 PM
bigwig's Avatar
.60 T3 will spool kinda late for a D series dont you think? one plus w/ the T3 .60/.63 is you wont run out of steam in the higher rpm range...but a .60 a/r might be a little big...i really am not 100% sure though.
Old Nov 2, 2003 | 05:25 PM
USDMMARK's Avatar
yeah i heard the t3 was a little big, and i heard it was difficult to tune, im gonna use my stock bottom end (d16a6) and maybe a z6 top end for higher top end, but this is gonna be daily driven, stock internal and just a bigger fuel pump, maybe msd iginition, but other wise pretty stock, with a turbo and intercooler piped on, so what now that ive given more info what do you think?
what does a sc61 come off of, eight psi will be eough for me that's why i was kinda leaning towards the rhb5 tiny and spools quick
thanks for the info guys
keep it coming
to awnser the question, Dr. D = d series motor yes lol
Old Nov 2, 2003 | 07:58 PM
USDMMARK's Avatar
Default Re: (Dr.D)
bump for the morning it's 12am
Old Nov 2, 2003 | 08:01 PM
ITSTOCK's Avatar
Default Re: (Dr.D)
i have a t25 turbo on my car, spools up extremely fast and pulls nice, ran a 13.9@100 on a d16z6 low boost
Old Nov 2, 2003 | 08:02 PM
USDMMARK's Avatar
Default Re: (ITSTOCK)
i know you do bro, ive been defending your time on the z6 vs. carrera. lol
Old Nov 2, 2003 | 08:27 PM
turbod16y8's Avatar
Default Re: (Dr.D)
out of those 3 turbo i would go with the 14b. thats what im running on my d16 and i love it. i used to run the ihi rhb5 and switched to the 14b. big difference. the pull up top is alot better with the 14b.
blown_LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">none of the above. get a T3 .42/.48 but most likely it will run out of steam at the end of your powerband...</TD></TR></TABLE>
I'm down with that !!! I had it on my teg and it's great turbo for decent hp figures and dailly driving.
Old Nov 2, 2003 | 08:40 PM
Eibach95Civic's Avatar
Community Builder
Default Re: (blown_LS)
my brother has a 93 hatch w/ 95 d16z6 motor, with a t25 runing 8psi... VERY VERY GOOD PULL.. i think his last time was low 13's
Old Nov 2, 2003 | 09:10 PM
darkracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">i have a t25 turbo on my car, spools up extremely fast and pulls nice, ran a 13.9@100 on a d16z6 low boost</TD></TR></TABLE>
he knows,
i built the same setup, just have to install it. You can have a full 10psi at around 3000 rpm. great for daily driver/ occasional track duty.
Old Nov 2, 2003 | 09:15 PM
PHiZ's Avatar
Default Re: (darkracer)
He specifically said homemade setup, and I think he meant to communicate junkyard setup.... so the SC61 fad isn't going to suite his needs.
I don't want to hijack the thread's intended direction, but also which turob has the easiest flanges to work with?
-PHiZ
Old Nov 2, 2003 | 09:30 PM
2000vsm's Avatar
Default Re: (PHiZ)
get the t25 or 14b... rhb5 is too small.. although it spools up quickly, it doesn't get to 8psi as soon as you think....
it starts spooling like 1500rpm but around 3500 is where 8psi is... of course i never floor it below 3.2k so maybe it does spool up around 3000 if u floor it from idle... i dunno
it's not giving much hp at top end. that's all i found out.. missing like 20-30 hp
Old Nov 3, 2003 | 07:13 AM
USDMMARK's Avatar
Default Re: (2000vsm)
thanks, i think ill just try to find a t25 at the junkyard tomorrow.
thanks for all the facts, deff. made a diff in my choices.
Old Nov 3, 2003 | 07:32 AM
reaction360's Avatar
Default Re: (Dr.D)
my choice T25 off of an SR20det good spool, nice AR's .84/ .64
also i was curious how a T3 .42/.63 would do on a d16y8? we just put one on my buddy's civic "homemade kit" and didnt realize it had a .63 ar tilll we put it in. I've never seen one with that type of setup, usually they're .42/.48.
Old Nov 3, 2003 | 07:53 AM
USDMMARK's Avatar
Default Re: (reaction360)
(local junkyad) copher pulls some of there more expensive stuff sometimes, like ecus and turbos stuff like that, besides the motor and interior, i guess it's stuff people could steal anyways, if they have turbos pulled already, how can i identify the t25? any numbers printed on the housing?
tia
Old Nov 3, 2003 | 08:24 AM
Default Re: (Dr.D)
you could look at the difference in flanges. the dsm t25 had an almost square flange with a round inner opening. the nissan t25 is a rectangular flange a lil smaller then a t3 flange and is about 4" wide. and i believe the ihi turbo has a completely different flange of its own. and a T3 will just be bigger then them and usually has a standard 5-bolt exhaust housing. good luck
Old Nov 3, 2003 | 08:28 PM
USDMMARK's Avatar
what type of turbo is the starion turbo, and what is a vj11 and what is the vj11 off of?
Old Nov 3, 2003 | 11:26 PM
Default Re: (Dr.D)
i believe the starion turbo is a td05 which is about the size of a small T3 i believe
