Clutch got stuck!!!
Old Nov 1, 2003 | 09:59 PM
incognitoracerr's Avatar
Default Clutch got stuck!!!
Ok I finally broke my car in and I was taking it for a test drive. I power shift and when I did the clutch pedal did not want to go down...it got stuck...this is on a b16Sir2 on a 1994 civic ex. It is a cable tranny with the hasport cable to hydraulic conversion kit. When I power shift it got stuck...so I pulled over to the side for a few minute and after like 5-10 minute I was able to push the clutch in but it was stuck for a while...don't want this to happen again...any ideas?
Modified by incognitoracerr at 10:18 AM 11/4/2003
Old Nov 1, 2003 | 10:02 PM
K20EG's Avatar
Default Re: Clutch got stuck!!! (incognitoracerr)
sounds like a broken pressure plate
Old Nov 2, 2003 | 09:12 AM
Se-rv-Tak's Avatar
Default Re: Clutch got stuck!!! (K20EG)
Did you install your clutch? yourself?
Old Nov 2, 2003 | 10:17 AM
Suprdave's Avatar
You need to re-bleed the system and check the hydro-cable conversion for binding where the slave pushes up on the lever. Had that problem a few years ago...adjusted everything and it was gravy.
The clutch isn't broken.
Suprdave
Old Nov 2, 2003 | 01:04 PM
Default Re: Clutch got stuck!!! (Suprdave)
Yes I did install everything myself but it was working fine...I have done this many times. But this is my first time doing it with a conversion kit...and that sucker got stuck...I doubt the pressure plate and clutch are broken for the simple fact that when it get's stuck if you leave it alone for a few it works again and the clutch feels fine...its just the pedal that get's either hard to push in or it gets stuck to the floor.
Old Nov 3, 2003 | 04:55 AM
Pikachu's Avatar
Mine got like that but that was because my slave cylinder went out. Changed it out and it runs smooth now.
Old Nov 3, 2003 | 04:33 PM
Default Re: (Pikachu)
I took my car out for a test drive and the clutch seemed fine except when I shift at higher rpm then I lose the clutch pedal and I have to pull over until i get pedal again...takes about 2 minutes before I can get a good pedal to take off again. I don't power shift but if I run each gear up to at least 6k rpm and i try to shift at that high rpm i shift successfully but I lose the pedal after that...no pressure at all..I have to wait a while before it gets pressure again...any ideas?...an no I am not power shifting...it drops about 2k almost before I shift...it just seems to do this at high rpms...sometimes when I start the car I lose clutch pedal but thats sometimes...and I have not hydraulic fluid leak so I am ok there
Old Nov 3, 2003 | 11:00 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incognitoracerr &raquo;</TD></TR><TR><TD CLASS="quote"> When I power **** it got stuck...</TD></TR></TABLE>
i think u need more fiber in your diet.
Old Nov 4, 2003 | 06:17 AM
Default Re: Clutch got stuck!!! (LsVtec92Hatch)
HAHA...yeah that was a real type -o
Old Nov 4, 2003 | 06:43 AM
hondaZvic's Avatar
hahaha LOL **power ******. i bet that hurt.. or felt really good.
Old Nov 9, 2003 | 01:22 PM
hondaZvic's Avatar
Default Re: (blcwsfly20)
**edited**
Modified by hondaZvic at 6:18 AM 11/10/2003
Convert
Feb 1, 2009 09:51 PM
C1CRX
13
Apr 23, 2007 09:42 AM
g1zcteg
Jun 7, 2006 09:48 PM
Black R
13
Nov 15, 2004 08:14 AM
