rev limit ?
i did a swap in my 88 crx. i put in a d15z1 with the dpfi intake system. soit is still set up as a dpfi. i used the dpfi dist. and computer. now the problem i have is the car will not rev pass 4k rpms with out feeling like it hit the rev limiter. it is also real slugigish. i am really lost and do not have any idea what to do! SOMEBODY PLEASE HELP!!!!!!!!!
code 4 on ecu
crank angle sensor
sensor its on the distribuitor
make sure the dizzy its positioned correctly
make sure the engien is on time
make sure the dizzy conectors all the pins are in
make sure the ecu plugs are in tight
reset the ecu
crank angle sensor
reset the ecu
nayrone
Nov 2, 2004 08:18 AM
nayrone
Nov 1, 2004 12:09 PM
