C.E.L Code 1 and O2 sensor mystery.
Old Nov 1, 2003 | 06:00 PM
Silver_Rex's Avatar
Default C.E.L Code 1 and O2 sensor mystery.
Ok this is my problem. When im driving around on the freeway/streets and I proceed to get off the freeway when I began decelerating my CEL comes on and my ecu blinks 1 time.
Whats odd is that it only comes on after i slow down. I know an o2 only works after it heats up BUT I have drive from my house in South San Diego to San Marcos (more enough time to heat up) and the CEL wont come on untill I slow down. I have replaced it with 2 new bosch o2's and just purchased and exchanged 2 oem honda 02's.
I have heard a sticky throttle plate can also cause it to bring up the code.. which is something i also have.
Anyone have any idea's? And Yes I did a search and i couldnt find any answers
Thanks,
Mig
90 CRXSi Motor w/ 91 PM6 ecu
Old Nov 1, 2003 | 06:34 PM
USDM 4G VTEC's Avatar
Default Re: C.E.L Code 1 and O2 sensor mystery. (Silver_Rex)
maybe theres a fracture on the wiring from the ecu to the O2
even fi the O2 are good theere might be something wrong in between
Old Nov 1, 2003 | 06:51 PM
Silver_Rex's Avatar
Default Re: C.E.L Code 1 and O2 sensor mystery. (USDM 4G VTEC)
I also thought that i may have a short but i used my meter to test out the signal (and also burning myself in the process) but i was getting a correct signal from both ends and even moved the cable around..
Mig
Old Nov 2, 2003 | 04:42 AM
Caleb V's Avatar
Replace the Map sensor with a know good loaner. I burnt a couple of O2 sensors up with a bad MAP sensor either they were cheap O2 sensors or the MAP sensor caused them to smoke. In a different car 1989 Civic Base I have also had an O2 sensor code keep popping up and it didn't go away until I tried a different MAP sensor.
Old Nov 2, 2003 | 06:57 PM
Silver_Rex's Avatar
Default Re: C.E.L Code 1 and O2 sensor mystery. (Caleb V)
Hmm ill try the map sensor....
Old Nov 3, 2003 | 07:48 PM
Silver_Rex's Avatar
So does anyone have an extra map sensor lying around I could buy?
Mig
JeffBro
Engine Management and Tuning
14
May 7, 2011 11:04 PM
Oakmanx
Jan 31, 2006 05:12 AM
terminaloverlowd
Oct 1, 2004 09:03 AM
EG2 SiR
Mar 4, 2004 10:35 AM
FLIPboi
Sep 24, 2002 07:34 PM
