Car won't start ... I ran over a fat ditch .. ?
Old Nov 1, 2003 | 03:29 PM
LowBuckRacin's Avatar
Default Car won't start ... I ran over a fat ditch .. ?
I ran over a ditch last week and coolant started leaking like crazy. So I'm like Oh ****, my radiator. I wasn't far from home so anyways I keep driving and then next thing I know my car loses power, then stalled, then died. I tried to start it up but it won't crank. I'm thinking it's my distributor but I'm not really sure. I need a 2nd opinion. It doesn't crank and makes a weird sound when i'm trying to start it. If it is my distributor, how much would it cost to buy another one and can I install it myself ? Any links on How-To's ?
Car is a 90 Crx Si' ... Thanks for any help !!
Old Nov 1, 2003 | 04:29 PM
Apollo's Avatar
Default Re: Car won't start ... I ran over a fat ditch .. ? (LowBuckRacin)
How bas was this "ditch" did you look under the car for damage in the bay anywhere? Check the codes? etc...
Old Nov 1, 2003 | 04:47 PM
1.8Tea's Avatar
Default Re: Car won't start ... I ran over a fat ditch .. ? (Apollo)
Ummm...if it was leaking coolant and you kept driving it, there is nothing there to cool the engine down. Did the engine start to smoke?
Old Nov 1, 2003 | 05:38 PM
brent_G's Avatar
Default Re: Car won't start ... I ran over a fat ditch .. ? (1.8Tea)
i read the title really fast and i thought it said you ran over a fat "bitch"! oh well glad no big girls got hit, and good luck with your prob
Old Nov 1, 2003 | 06:10 PM
Default Re: Car won't start ... I ran over a fat ditch .. ? (screamincivik)
the ditch i ran over wasn't really big but i know i messed up my radiator. Yeah, smoke did come out when the car died. I also checked underneath the car and everything seems to be in order. I have no clue how to check the codes, any tips ?
Old Nov 1, 2003 | 07:08 PM
Steve90HB's Avatar
move your passenger carpet (where your ECU is located) look at the little window - you'll see it, turn the key to the on position, it WILL flash one time no matter what, so don't count that one. After it does the one flash it will start to flash constantly - count them
then once you get the number, go here https://honda-tech.com/zerothread?id=468260
also, have you checked your oil? it might be possible you messed up your oil pan and leaked a lot of oil... that would really suck
Old Nov 1, 2003 | 08:16 PM
Default Re: Car won't start ... I ran over a fat ditch .. ? (Steve90HB)
k .. im gonna go try that tomorrow .. and no, no oil is leaking out so it can't be the oil pan ..
Old Nov 1, 2003 | 08:18 PM
NathanMorris's Avatar
so long as everything under looks good.....and the ECU checks out good...then my next suspicion would be overheating caused something really funky?
- Nathan
Old Nov 1, 2003 | 11:29 PM
Default Re: Car won't start ... I ran over a fat ditch .. ? (92Lx)
what do you mean by " really funky "
Old Nov 1, 2003 | 11:36 PM
chadmasterc's Avatar
sounds like you locked up your engine, nice going. good luck on your new engine.
Old Nov 2, 2003 | 03:43 PM
firstgenrex's Avatar
yeah dude to fix theis problem buy a new engine and dont drive it without coolant. when my firneds laser had a rod knock, he let me try to blow the engine for him for $5 and i tried and after holding it at 6k for about 5 mins, the rpms dropped and it stalled. i tried to start it and all it did was crank and *slowly* cranked. it was basically siezed up. sounds like almost the same happened to u,
dalek
Aug 22, 2008 03:03 AM
Its me DUB
14
May 13, 2005 09:40 AM
LsVtecDA
Mar 30, 2003 05:17 PM
chirp2hrd
Sep 1, 2002 03:26 PM
sshaikh01
Feb 18, 2002 08:49 PM
