shifting questions
Old Sep 6, 2001 | 01:46 PM
FlipboiGSR's Avatar
New User
Default shifting questions
if goin to a stop and im in 4th gear or sumtin, is it ok to go from 4th to neutral, then when its time to go start in 1st gear with going through 3rd n 2nd?
Old Sep 6, 2001 | 05:41 PM
pstreck's Avatar
New User
Default Re: shifting questions (FlipboiGSR)
Ok i'm think what you mean is if you stop can you go from 4th to 1st without going through second and third, the answer to that is yes.. but dont be skippin gears up shifiting or down shifting when your moving, it can kill your synchros
Old Sep 6, 2001 | 07:35 PM
Jesse H's Avatar
Default Re: shifting questions (pstreck)
if you want to skip gears, just double clutch and rev match.
Old Sep 6, 2001 | 08:01 PM
redteg1's Avatar
Default Re: shifting questions (Jesse H)
wat does double clutch and rev match mean?
Old Sep 6, 2001 | 08:14 PM
Jesse H's Avatar
Default Re: shifting questions (redteg1)
normally you push the clutch in, shift to next gear, let the clutch out.
double clutching involves this:
push the clutch in, shift to neutral, let the clutch out, let the clutch back in, shift to next gear, let the clutch out
letting the clutch out in neutral stops the input shaft from spinning, this makes it much easier on your synchros. I also double clutch when I'm coming to a stop, before putting it in first gear. You'll physically feel it going into gear with less resistance.
Rev matching is done everytime you shift, when you give it gas by matching the revs. If you didn't rev match, each gear shift would be jerky. Rev matching becomes much more important when downshifting or upshifting while skipping gears.
hth'd
Old Sep 6, 2001 | 08:19 PM
Slain's Avatar
give that man a beer couldnt have put it any better
Old Sep 6, 2001 | 09:16 PM
vteg's Avatar
New User
Have I been doing this wrong? The way I rev match, for example downshifting to first at 20mph, I press the clutch. Move shifter to neutral, release clutch. Blip throttle for rev match. Press clutch and downshift. It drops into first like butter. Most of the time anyway
Old Sep 6, 2001 | 11:43 PM
sLo B18b's Avatar
New User
Default Re: shifting questions (vteg)
is it bad to shift from 3rd to 5th??
Old Sep 7, 2001 | 12:59 AM
dustin's Avatar
Default Re: shifting questions (sLo B18b)
Jesse H: Letting the clutch out in neutral just makes the layshaft RPM match the engine RPM. It does not stop it or anything.
How I double clutch....
1) shift to neutral
2) clutch out
3) rev to the destination RPM for the destination gear (brings layshaft up to speed)
then very quickly:
4) clutch in
5) shift to destination gear
6) clutch out
Dustin
Old Sep 7, 2001 | 09:49 AM
Jesse H's Avatar
Default Re: shifting questions (dustin)
Doh...I always get that confused.
You think after looking at the stupid flywheel on various cars for ever I'd have it down pat by now.
Know what's cool about a 300ZXTT? It's rwd. That means you can drop the tranny in less than an hour. Lucky basturds.
Old Sep 12, 2001 | 03:53 PM
dustin's Avatar
Mike used to have a 300ZX. It was not very reliable so he bought a prelude
Dustin
Old Sep 12, 2001 | 09:07 PM
TypeRInNeed's Avatar
New User
Please correct me if im wrong but isnt the whole point of double clutching to rev match. If you dont rev match then double clutching is absolutly useless, thats the whole point of doing it. It saves your synchros and is used in racing when downshifting into corners as to not upset the balance of your car. Seriously if im wrong then tell me but this is what ive always understood. Oh and skipping gears when downshifting isnt very harmful to your synchros even if you dont double clutch and rev match, just make sure your going slow enough for the gear so that you dont run those rpms too high.
ablack934doorcivic
Nov 1, 2005 02:02 PM
petrv
Aug 17, 2004 02:10 AM
Chief Brody
Aug 4, 2004 09:28 PM
Kevins2k
Jun 11, 2003 10:56 PM
tc
Jul 31, 2001 10:10 AM
