which FPR is the best?
Old Nov 1, 2003 | 12:21 PM
projecthybrid04's Avatar
Default which FPR is the best?
I was thinking of getting an Ericks racing?
Old Nov 1, 2003 | 01:51 PM
hontegra's Avatar
b&m fpr are prety good
Old Nov 1, 2003 | 05:49 PM
naturelovindc2's Avatar
Default Re: (hontegra)
My AEM seemed to work fine until a friend of mine went to pull the vacuum line off it and the nipple broke off. I just bought a B&M but I'm considering trying to fix the AEM and sell the other one. I've heard it mentioned a few times that I'd be better off with the AEM.
Old Nov 1, 2003 | 07:35 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: which FPR is the best? (projecthybrid04)
Aeromotive, hands down!!!!!!
Old Nov 2, 2003 | 07:02 AM
strepto's Avatar
Default Re: which FPR is the best? (Mista Bone)
I got the AEM on order as well. What fuel pressure gauge are you guys running? Im looking to get that too!
BTW: Still looking for another AEM FPR, gauge and rails as well!
Old Nov 2, 2003 | 07:10 AM
so no one has used an ericks racing one?
Old Nov 2, 2003 | 12:58 PM
Mista Bone's Avatar
D Tranny Guru
The problem with the B&M and Ericks, they won't flow enough fuel to drop idle pressure when using a 255 LPH HP pump.
This tends to make them stick/hang open. Which is BAD news when your spraying/boosting.
Old Nov 2, 2003 | 01:07 PM
SOHCArchangel's Avatar
aeromotive
Old Nov 2, 2003 | 06:24 PM
jdkindle's Avatar
any experience/comments on SX?
Old Nov 2, 2003 | 06:27 PM
[QUOTE=Mista Bone]The problem with the B&M and Ericks, they won't flow enough fuel to drop idle pressure when using a 255 LPH HP pump.QUOTE]
So what do u recommend?
Old Nov 3, 2003 | 11:08 AM
bump
Old Nov 3, 2003 | 11:52 AM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">The problem with the B&M and Ericks, they won't flow enough fuel to drop idle pressure when using a 255 LPH HP pump.
This tends to make them stick/hang open. Which is BAD news when your spraying/boosting.</TD></TR></TABLE>
PLEASE explain more..
what part sticks/hangs open?
why would it be bad for FI/nos setup?
Old Nov 3, 2003 | 12:24 PM
Kataku2K3's Avatar
Default Re: which FPR is the best? (Charlie Moua)
Magnaflow or Aeromotive ... I would go with the Mag first, we run the 9950 on Duc's 700whp+ EJ6, Ralph's 600rwhp RX-7, and his ~1000rwhp Supra (those are all supporting built FI setups along with Pro Star 600 EFI pumps) and they all work GREAT... MagnaflowFPRs
Modified by Kataku2K3 at 5:17 PM 11/3/2003
Old Nov 3, 2003 | 12:31 PM
mr. wu's Avatar
Default Re: which FPR is the best? (jdkindle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdkindle &raquo;</TD></TR><TR><TD CLASS="quote">any experience/comments on SX?</TD></TR></TABLE>
i got an sx regulator, i've been running it for about 2 years know and i love it. sx is the ****!
Old Nov 3, 2003 | 03:57 PM
Mista Bone's Avatar
D Tranny Guru
when it sticks open, you won't notice it at idle. You end up bypassing all fuel back to the tank. The Walbro 255 HP pump can keep up and you'll never notice, AT IDLE!
But when you got to make a run, VERY low fuel pressure, like 15-20 psi when you need 50-60 psi.
Leanout and MELTDOWN.
Old Nov 3, 2003 | 05:56 PM
Default Re: which FPR is the best? (mr. wu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. wu &raquo;</TD></TR><TR><TD CLASS="quote">
i got an sx regulator, i've been running it for about 2 years know and i love it. sx is the ****!</TD></TR></TABLE>
Where is best price i can find the sx regulator at?
Old Nov 3, 2003 | 06:22 PM
mr. wu's Avatar
i actually got mine from some company that builds air planes, i guess that they are the same regulators that they use for the planes. i got it for like around $200. a little exspensive, but i do believe that you can get an airimotive one from summit for like $125, the airimotive and sx are pretty much from the same exact regulator. i also saw an sx regulator for sale in the classifieds like a week ago, i don't remeber the price though.
Old Nov 3, 2003 | 08:08 PM
jdkindle's Avatar
I found it for $150 or 160.........cant remember the site right off hand and dont have time to look around really, but that will give you a goal to reach
Old Nov 4, 2003 | 02:49 AM
ATS*Mark's Avatar
OG triple OG
i want a fuel pressure regulator that can bolt to the fuel rail(car specific)
that will safely run correct pressure with a 255 fuel pump... is there any out there??? other than aem
Old Nov 4, 2003 | 03:00 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: which FPR is the best? (Hella_JDM)
AEROMOTIVE
Old Nov 4, 2003 | 07:54 AM
mr. wu's Avatar
my sx one is conected to the fuel rail right at the very end, all you need is a 1/2 in. to 10 an fitting and you'll be good.
Old Nov 4, 2003 | 09:55 PM
ATS*Mark's Avatar
OG triple OG
aeromotive doesnt make a fpr for a 99 ex......
Old Nov 5, 2003 | 09:41 AM
SLaMmEd GsR's Avatar
Default Re: (naturelovindc2)
The same problem happened with the AEM FPR that i bought a while back, except when i put on the BENEN TRI POD bar, it broke off the nipple port for the vacum hose. Does anyone know a place that can fix this, besides sending it back to AEM? I already talked to a local shop and they said that it's my fault and AEM won't cover it.
Modified by SLaMmEd GsR at 6:55 PM 11/5/2003
Old Nov 7, 2003 | 05:07 PM
Richard.'s Avatar
Default Re: (SLaMmEd GsR)
So i guess AEM is crap? Now to look into the SX.
Old Nov 7, 2003 | 06:25 PM
mey_xanng's Avatar
Default Re: (Spoon)
Any one have any expirience with the Stillen FPR, with or without the gauge?
