enter if u have a VIS Carbon FIber hood ASAP!!!!
Old Nov 1, 2003 | 10:58 AM
GreenMachineRex's Avatar
Default enter if u have a VIS Carbon FIber hood ASAP!!!!
hey people, i just picked up a ZC VIS hood....
but it says 88 crx under the hood, and i have a 91!?
i don't have my car right now but whats that year for?
do i need any parts off my stock hood for this one? i don't see a latch thing under the hood? confused! thanks
Old Nov 1, 2003 | 11:07 AM
XxLuckyLisaxX's Avatar
Default Re: enter if u have a VIS Carbon FIber hood ASAP!!!! (GreenMachineRex)
hmm well you dont need the latch because you are supposed to use hood pins, are all crxs hoods interchangable 88-91 9(i dont know for sure i dont have one) well if you know they are which i think so then dont trip bout the year being there
Old Nov 1, 2003 | 01:13 PM
R6Boy69's Avatar
all crx hoods are the same 88-91
Old Nov 1, 2003 | 01:57 PM
KTeller8's Avatar
Default Re: enter if u have a VIS Carbon FIber hood ASAP!!!! (crXBoy69)
88-91 hoods are the same and you use HOOD pins
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 &raquo;</TD></TR><TR><TD CLASS="quote">all crx hoods are the same 88-91</TD></TR></TABLE>
Old Nov 1, 2003 | 02:59 PM
quis23's Avatar
Default Re: enter if u have a VIS Carbon FIber hood ASAP!!!! (KTeller8)
mine has latch...also you should be using hoodpins and the latch to safely secure your hood
Old Nov 12, 2003 | 11:28 AM
rice a roni's Avatar
Default Re: enter if u have a VIS Carbon FIber hood ASAP!!!! (quis23)
how you supposed to put hood pins in?
Old Nov 12, 2003 | 11:37 AM
manson's Avatar
Default Re: enter if u have a VIS Carbon FIber hood ASAP!!!! (sohc_civic)
i have a latch in mine. i'll check under the hood and see if it says anything for the year.
to put hood pins in you must drill through the hood, and headlight support. its a pain in the *** and if you mess up...well it ruins the look of your $500.00 hood.
Old Nov 12, 2003 | 12:38 PM
slywfbpsi's Avatar
Default Re: enter if u have a VIS Carbon FIber hood ASAP!!!! (mansonclubpuir)
I had a vis carbon fiber hood, and hood pins are not required, I have had it for over a year, with excessive speeds and high winds, and never has the hood flexed or blown off, or gave me any trouble.
Old Nov 12, 2003 | 08:03 PM
R6Boy69's Avatar
Default Re: enter if u have a VIS Carbon FIber hood ASAP!!!! (slywfbpsi)
same here had mine for over a year with just a latch and it has never given me any problems
Old Nov 12, 2003 | 08:06 PM
brent_G's Avatar
no problems here either. i see if flapping alot by the windshield from the wind tunneling through, but thats the extent of it. Kinda makes me nervous somtimes but when i geot out and grab a hold to make sure its sturdy i know its not goin anywheres
Old Nov 12, 2003 | 08:21 PM
NathanMorris's Avatar
Default Re: enter if u have a VIS Carbon FIber hood ASAP!!!! (screamincivik)
with the VIS hood, you shouldn't need the hood pins, but it may be a smart idea to install them if you're into that kind of thing, for extra safety.And yes, the hoods are all the same 88-91
- Nathan
Old Nov 12, 2003 | 09:19 PM
crx98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex &raquo;</TD></TR><TR><TD CLASS="quote">
do i need any parts off my stock hood for this one? i don't see a latch thing under the hood? confused! thanks</TD></TR></TABLE>
take the latch from your stock oem hood and put it on the vis carbon fiber hood
hondacrx2
Oct 12, 2007 10:16 AM
spunautosports
Dec 5, 2006 04:16 PM
turboZChatch
Dec 12, 2004 11:58 AM
starbury
11
Aug 16, 2004 12:36 AM
