what do you use to cut siilicone couplers clean?
i got a big *** roll of silicone couplers from roadraceengineering and im curious what do you guys use to cut these clean >?? razor doesnt work so well unles syou got accurate hands and eyes .. give some imput thanks
i think its the same stuff as the couplers we have for semi trucks here.. i put it in a vice right where im gonna cut it and then use a razor..
I used to use a cheap mitre box and a hacksaw...
the mitre box is basically a wood c chanel piece with slots across at diferent angles.. it holds the silicon, and makes sure the cut is straight
I've used devices like this on a lot of radiator/fuel/oil hose, personally up to 1.5in
http://www.hdhudson.com/distri....html
-PHiZ
-PHiZ
tighten a hose clamp on and use it as a guide to cut it with a razor.when you get to the part where you turn the bolt, just loosen it and rotate it a bit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">tighten a hose clamp on and use it as a guide to cut it with a razor.when you get to the part where you turn the bolt, just loosen it and rotate it a bit </TD></TR></TABLE>
so far i like that idea the best !!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T »</TD></TR><TR><TD CLASS="quote">bandsaw
stan</TD></TR></TABLE>
go to the kitchen find the biggest sharpest non serrated knife possible. use some silicone spray or wd 40 and use the knife just like a saw. You'll get a nice clean straight cut.
power tools
power tools
ghetto R
Nov 22, 2001 09:46 AM
keithv
Jun 14, 2001 06:44 PM
