preset wastegate at 7psi
Old Nov 1, 2003 | 07:43 AM
respectblades's Avatar
Default preset wastegate at 7psi
are wastegates set at 7psi from the shop
i'm planning on piecing together a custom setup ...
and was wondering if the waste gates comes set at 7psi
and where can i buy a fuel riser
Old Nov 1, 2003 | 07:58 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: preset wastegate at 7psi (respectblades)
I would flame you but it's saturday and Im nice on Saturdays. The best way t5o answer your questions would be to do a little research to have an idea of what you want to do. Set goals and that makes life easier too. Froam Tail you can pick which wastegate spring you want....(PSI)
A "fuel raiser"- fuel managment.Hondata, aem speedpro.
Old Nov 16, 2003 | 11:32 AM
Roky's Avatar
Default Re: preset wastegate at 7psi (HybridcivicLS-T)
with a 7psi spring, you can make at least 7psi of pressure, right?
how much pressure is the most you can make with a 7psi spring? I guess with the wastegate you can adjust the pressure manually but I'm not sure.
If you attach a Boost Controller for switching between Hi and Lo pressure settings, how does this work together with hondata? do you have to to tune fuel maps for the Lo as well as for the Hi pressure?
thanks
Old Nov 18, 2003 | 12:30 AM
Foozball26's Avatar
>--<-0 ............................................|||||| |||
Me running into wall b/c of this question
but in all seriousness these are basic turbo questions that can be answered with a little research
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">Froam Tail you can pick which wastegate spring you want....(PSI)</TD></TR></TABLE>
Antwaine tell me where to get a Tail wastgate, my tial sucks
Old Nov 18, 2003 | 05:03 AM
Muckman's Avatar
Moderator in Chief
Default Re: preset wastegate at 7psi (Foozball26)
Why would you possibly think all shops set wastegates to 7 psi regardless of application? No, they dont.
Can we start a FAQ thread and sticky it to the top?
Old Nov 18, 2003 | 05:09 AM
BROOD's Avatar
Default Re: preset wastegate at 7psi (Muckman)
You can get spring settings at various pressure levels, not just 7psi. The main thing is that with an example of a 11 psi spring....the WG will allow the turbo to boost up to around 11psi. You can modify this boost pressure with a boost controller (electric or manual) and get more pressure from the same spring....but not less.
If you want less boost than the spring is initially set for you need to install a different rates spring (lower).
.......which you would have found with some research
Old Nov 19, 2003 | 09:44 AM
Default Re: preset wastegate at 7psi (BROOD)
well yeah i did a little research and found my answer so no need to flame
hondamyheart
Jun 20, 2018 09:57 PM
Kid-jdm-teggy
Mar 19, 2014 03:02 PM
.RTErnie
Jul 15, 2006 10:06 AM
opto_isolator
Apr 13, 2006 06:48 PM
