I hate B16A2 oil filters *rant*
Old Nov 1, 2003 | 07:16 AM
JoshuaVTEC's Avatar
Default I hate B16A2 oil filters *rant*
Well everyone knows the Si oil filter is in the most in-oportune location ever... no room for maneuvering your hands, laying under the car it's a hard angle, can't fit a strap wrench in there, can't come at it from the top due to the intake manifold, oil always spills when you take the filter off...
I'm just having a bitch of a time with doing my oil change today. You'd think Honda would think the oil filter location through a little more
Old Nov 1, 2003 | 07:20 AM
MADEinJAPAN's Avatar
Default Re: I hate B16A2 oil filters *rant* (JoshuaVTEC)
Try a jar opener...one of those little rubber circles. Thats what I use. Maybe it will help..maybe not.
Old Nov 1, 2003 | 07:22 AM
DCStreetHtch's Avatar
Default Re: I hate B16A2 oil filters *rant* (MADEinJAPAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADEinJAPAN &raquo;</TD></TR><TR><TD CLASS="quote">Try a jar opener...one of those little rubber circles. Thats what I use. Maybe it will help..maybe not. </TD></TR></TABLE>
'tis what i use!!
-Bryan-
Old Nov 1, 2003 | 07:30 AM
TwistedSI's Avatar
I don't have a problem getting a wrench on it enough to loosen it and then just take it off by hand. One of these days I am going to buy one of those "sockets" that fits over the end of the filter so you can use a ratchet to take it off. But it does suck how oil spills over everything. I usually tuck a couple rags up there to try and catch most of it and then I do a wipe down before I take it off the ramps.
Old Nov 1, 2003 | 07:32 AM
slamed93si's Avatar
Default Re: I hate B16A2 oil filters *rant* (EGStreetHtch)
jackson racing makes a oil filter relocation kit for it i have one on my 99 si and i dont even have to go under the car to change the filter its good i love it
Carlo's Avatar
I think you're only supposed to tighten it by hand anyway, so it shouldn't be too hard to losen it. I've never needed one of those oil filter wrenches.
Old Nov 1, 2003 | 07:59 AM
degooser's Avatar
Default Re: (Carlo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carlo &raquo;</TD></TR><TR><TD CLASS="quote">I think you're only supposed to tighten it by hand anyway, so it shouldn't be too hard to losen it. I've never needed one of those oil filter wrenches.</TD></TR></TABLE>
or if its really hard..stick a screwdriver towards the very end of it and twist...
Old Nov 1, 2003 | 08:08 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (degooser)
I don't have a problem with mine ever. With the car jacked up it's pretty easy to get your hand in there. If you can't take it off with a little elbow greese then it's on way to tight. It ususally just takes me about 3 strong twists to loosen it. Like a charm. I just changed mine yesturday as a matter of fact. Took all of 12minutes. Most of the time was waiting for the oil to drain.
Old Nov 1, 2003 | 08:11 AM
2lua's Avatar
drain the oil first, then use a pick or a some with sharp point the punch a small hole at the end of the oil filter to help the oil drain out of the filter back into the oil pan faster, then lose the oil filter without any oil dripiping on your exhaust or you.
Old Nov 1, 2003 | 09:19 AM
PupaScoopa's Avatar
Default Re: I hate B16A2 oil filters *rant* (2lua)
I use the K&N oil filter which as a 1" hex at the end, so a socket can fit easily. Don't tighten it so much that you have to put a wrench on it anyway. I wish there was a longer version of this filter to ease install/removal.
Old Nov 1, 2003 | 09:35 AM
Frozen E's Avatar
H-T White Ops
I have one of those oil filter adapter things. It's made by Flotool. Get the #2. It fits right over the end of the oil filter. It has a 3/8" drive slot on the back of it. Get either that or just usethe Fram oil filters that have the grippy stuff on the end of 'em.
Hammett's Avatar
I always use by belts to get them off..
Old Nov 1, 2003 | 12:09 PM
Buzzbomb's Avatar
Why in the world are people suggesting stabbing the filter to get it off? GEEZ, talk about bad advice.
To repeat the intelligent replies, if you need a wrench of any kind to get the filter off, then it's too tight. I can always get mine off from ABOVE the car and loosening the filter with my hand.
Here is another good tip. When you start draining the oil wait about 20 to 30 min. before taking the filter off. This lets the oil drain out of the filter so you don't end up with a big mess.
The car opener was a good idea.
Fram makes filter with the grippy end on it, that my help you. But seriously, don't start stabbing it with a screwdriver, just don't tighten it so hard next time.
Old Nov 1, 2003 | 12:49 PM
vladd's Avatar
Default Re: I hate B16A2 oil filters *rant* (Buzzbomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">Why in the world are people suggesting stabbing the filter to get it off? GEEZ, talk about bad advice.
Fram makes filter with the grippy end on it, that my help you. But seriously, don't start stabbing it with a screwdriver, just don't tighten it so hard next time. </TD></TR></TABLE>
what's so bad about stabbing it? you're throwing it away anyway.
Old Nov 1, 2003 | 04:22 PM
Cynical 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Well everyone knows the Si oil filter is in the most in-oportune location ever... no room for maneuvering your hands, laying under the car it's a hard angle, can't fit a strap wrench in there, can't come at it from the top due to the intake manifold, oil always spills when you take the filter off...
I'm just having a bitch of a time with doing my oil change today. You'd think Honda would think the oil filter location through a little more </TD></TR></TABLE>
Old Nov 1, 2003 | 04:31 PM
JDMlyfestyle's Avatar
Default Re: I hate B16A2 oil filters *rant* (Revolveu2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolveu2 &raquo;</TD></TR><TR><TD CLASS="quote">
haha thats funny ****. Does any one happen to have a pic of there oil filter relocated. i think it would look kind of akward somewhere else.
Old Nov 1, 2003 | 04:40 PM
mycivicstoo(s)low's Avatar
Default Re: I hate B16A2 oil filters *rant* (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">
haha thats funny ****. Does any one happen to have a pic of there oil filter relocated. i think it would look kind of akward somewhere else. </TD></TR></TABLE>Possibly, but people don't relocate it for looks.
Old Nov 1, 2003 | 04:44 PM
EVIL Hx Coupe's Avatar
Oil always spills down my arm when I take mine off in my HX... I always tighten it by hand but then when I try to take it off to change it, it's always too hard so I have to spend about 10 mins trying to get the wrench in there and losen it....
Old Nov 1, 2003 | 04:53 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">Fram makes filter with the grippy end on it, that my help you. But seriously, don't start stabbing it with a screwdriver, just don't tighten it so hard next time. </TD></TR></TABLE>
Stab the ******* filter.. who cares.
Wipe the oil off when you're done. Is that such a big deal?
I use K&N filters.. they have a large nut on the end to get a wrench on it.
Old Nov 1, 2003 | 05:01 PM
Ricey McRicerton's Avatar
Default Re: I hate B16A2 oil filters *rant* (civicdxtyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">
what's so bad about stabbing it? you're throwing it away anyway.</TD></TR></TABLE>
Yup, I have been known to stab them if I can't get them off pretty quick. Does'nt hurt a damn thing.
Old Nov 1, 2003 | 06:19 PM
Smith Wise's Avatar
Default Re: I hate B16A2 oil filters *rant* (Ricey McRicerton)
it is a bitch to get to......... my g/f's car, 00 Accent has an oil filter almost exactly where the filler plug is on our Honda trannies..... Accent has the block on the passenger side & tranny on the driver's side....... talk about easy to change
too bad her car looks like a tomato
Old Nov 1, 2003 | 06:27 PM
GimpyAccord's Avatar
Default Re: I hate B16A2 oil filters *rant* (Jswpstdoff)
I was being slick and stabbed a filter once, too bad it still wouldnt turn off ... then I was in DEEP **** :D
I just make sure my filters are never beyond hand tight, been doing it that way for maaaaany years (per my fathers advice) and its never failed me.
Old Nov 1, 2003 | 10:27 PM
tangb2023
Guest
Posts: n/a
Default Re: I hate B16A2 oil filters *rant* (GimpyAccord)
deal with it or buy a toyota, most of their oil filter is in front..
Old Nov 1, 2003 | 10:39 PM
boostedcivicsir's Avatar
Mr. Badwrench
Try an IS 300. then complain. i have no qualms with my eg, i will do 1000 eg filters. i hate the IS 300's.
Old Nov 2, 2003 | 01:06 AM
BanEL's Avatar
Default Re: I hate B16A2 oil filters *rant* (boostedcivicsir)
lube up the seal before putting the new filter back on. lol
if its stuck, hammer in a screw driver straight through the filter, and use the screwdriver to turn the filter.
i use fram filters, and they have that grip stuff on the end of it. its alot easier for me to turn it.
