B16a1 in CRX Starting issues with the p30? see insisde. . .
Old Oct 31, 2003 | 04:37 PM
PM-Performance's Avatar
Default B16a1 in CRX Starting issues with the p30? see insisde. . .
Ok heres the low down , my friends CRX DX has a b16a1 in it . the wiring harness is a CRX si harness.
the problem is when we put the obd0-obd1 harness in from Locash and put the P30 in it wont crank over.
We put the reg CRX si Ecu in and it fires right up , but obviously not the same power levels and Vtec. Could there be an issue with the injector harness and the impredance levels.
locash told him to just unplug the box and splice the wires together.
could that b the issue?
Lemme know thanks.
Old Oct 31, 2003 | 07:57 PM
moysaystor's Avatar
Default Re: B16a1 in CRX Starting issues with the p30? see insisde. . . (itr206)
It sounds like locash is steering you in the right direction;however, for your obd 1 ecu to funtion properly you will need to take out the inj.resistor box, and install the plug for the new O2 sensor.
I recommend taking off the CRX engine harness, so you can solder in the fuel injection/ power distribution block that is found on obd 1 civic /integras it can be found by the driver side back of the fire wall.
The obd1 fuel injector has two wires One wire is a 12 volt power source. You can get the power needed for the pwr. block if " i recall." the yel/blk wire from the wiring of the old obd0 resistor box. You will see this wire as you unistall the resistor box.
Old Nov 1, 2003 | 07:27 AM
Default Re: B16a1 in CRX Starting issues with the p30? see insisde. . . (moysaystor)
so are we assuming that the obd1 inectors arent evben getting a power source at all to pulse them ?
I wish i could explain more about it , but they did the wiring when i wasnt around and i didnt even have a chance to look at it yet, so im just going on the little info they are telling me
any i didnt cath the part about the 02 sensor?
Old Nov 1, 2003 | 07:29 AM
91civicEX's Avatar
use your obd0 injectors. when i tried to put in the obd1 injectors with no resistor box only one of them would work.
Old Nov 1, 2003 | 08:08 AM
moysaystor's Avatar
Default Re: B16a1 in CRX Starting issues with the p30? see insisde. . . (91civicLX)
Obd 1 o2 sensor is heated and has four wires. The obd 0 o2 is not heated and has only two wires.
Old Nov 1, 2003 | 08:15 AM
would that keep it form starting with the o2 issue?
also could i do that for now with the obd0 injectors just to see if thats the issue?
johnnan71
Mar 11, 2015 04:43 PM
chongfa_209
10
Jan 1, 2007 09:13 PM
mugen_teg
Sep 6, 2006 04:19 PM
FairlightRacing
Aug 9, 2005 08:44 AM
eric.
Jul 29, 2002 05:02 PM
