Head Bolts
Old Oct 31, 2003 | 03:51 PM
importimage's Avatar
Default Head Bolts
I have a 89 Civic Hatch and am in the process of rebuilding it back up to stock condition. I am curious if I can re-use the old head bolts?
Thanks - Jeff -
Old Oct 31, 2003 | 08:48 PM
Default Re: Head Bolts (importimage)
All I want to know is if you can re-use the OEM head bolts?
Old Oct 31, 2003 | 08:59 PM
sporkcrx's Avatar
Yep. Did it on my rebuild.
Old Oct 31, 2003 | 09:59 PM
Default Re: Head Bolts (sporkcrx)
Thank you very much!
Old Oct 31, 2003 | 10:23 PM
JonGP4's Avatar
why couldn't u? unless they are striped out.. bolts don't just go bad from loosening them.. afterall thats what they are meant for
Old Nov 1, 2003 | 12:32 AM
sporkcrx's Avatar
Default Re: (JonGP4)
Well I guess sometimes they stretch and you're not suppossed to re-use them, like a torque once only type of deal. But a lot of people have reused theirs and are fine, including me.
Old Nov 1, 2003 | 07:41 AM
notfastenough's Avatar
It will work, yes. But the bolts were originally designed to be self locking and not reusable. Over time you MIGHT have head gasket problems like blow-by from cylinder to cylinder.
Old Nov 1, 2003 | 08:25 AM
turboZChatch's Avatar
not unless u want your **** to break again u might get lucky but the old head bolts are junk its like ask ur self willu use your rod bearings again
Old Nov 1, 2003 | 08:31 AM
Limited S.L.I.P.'s Avatar
Default Re: (notfastenough)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough &raquo;</TD></TR><TR><TD CLASS="quote">It will work, yes. But the bolts were originally designed to be self locking and not reusable. Over time you MIGHT have head gasket problems like blow-by from cylinder to cylinder.</TD></TR></TABLE>
basically, but I reused the ones from the head I bought. saved me $100. Not building a race car and they were fine so I figured it would be ok!
Old Nov 1, 2003 | 08:41 AM
sporkcrx's Avatar
Default Re: Head Bolts (turboZChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboZChatch &raquo;</TD></TR><TR><TD CLASS="quote">not unless u want your **** to break again u might get lucky but the old head bolts are junk its like ask ur self willu use your rod bearings again</TD></TR></TABLE>
That's not a good analagy The bearings are wear items...that's like saying would you reuse your brake pads.
Old Nov 1, 2003 | 08:45 AM
What's wrong with re-using brake pads?
Old Nov 1, 2003 | 09:58 AM
Default Re: Head Bolts (notfastenough)
I am confused now. Do I need to get new ones or not?
Old Nov 1, 2003 | 11:45 AM
spaceman's Avatar
lol on the brake pads..everytime this topics comes up some people say its ok some dont,basically its up to
Old Nov 1, 2003 | 11:56 AM
Hybrid Invasion's Avatar
you guys are talking about the head studs for the exhaust manifold, correct?
Old Nov 1, 2003 | 12:06 PM
spaceman's Avatar
Default Re: Head Bolts (Hybrid Invasion)
i think he was asking about the head bolts that connect the head to the block...
Old Nov 1, 2003 | 12:10 PM
Default Re: Head Bolts (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">i think he was asking about the head bolts that connect the head to the block...</TD></TR></TABLE>oh. gotcha.
Old Nov 1, 2003 | 12:20 PM
spaceman's Avatar
hybrid how is your car running..i remember you were asking about the skunk2 im
Old Nov 1, 2003 | 12:43 PM
it's running really good actually. I have a few things that I got for it that i'm waiting to put on until I get everything I want so that I can put everything on at once. I was having a problem with cold starts and for a while I thought I either had bent valves or my timing was off, but I got the timing checked 3 separate times and it's dead on; turns out the mugen spec chip I have in my ecu is notorious with having rough cold start problems, so now I know exactly whats causing that problem. it's not really a problem at all, it's just annoying. Once the car heats up, it's fine, no hesitation or bogging whatsoever. My ride is gonna be a lot more fun to drive in the next month though
Old Nov 1, 2003 | 01:59 PM
KTeller8's Avatar
some say yes some say no.. its one of those items you dont want to be cheap and not do. 100 bucks now is what a few hundred you waste later?
feel safe, buy some good ones: AEBS like 115 or so...
Old Nov 1, 2003 | 02:42 PM
Default Re: Head Bolts (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">some say yes some say no.. its one of those items you dont want to be cheap and not do. 100 bucks now is what a few hundred you waste later?
feel safe, buy some good ones: AEBS like 115 or so...</TD></TR></TABLE>Yeah, i'm gonna completely agree with that idea. For the extra money it costs you, it buys you peace of mind as well, which is something I know i'm personally searching for as much as possible. 115 bucks for peace of mind really isn't too much to spend.
Old Nov 1, 2003 | 06:14 PM
Mista Bone's Avatar
D Tranny Guru
if you retorque the head bolts after 500 miles and at first 3000 mile oil change, you'll never have a problem.
Just like you had to do with them old V8's I was raised on, nothing new.
Anybody want 10 new style torque to yield head bolts????
#90005-pm3-004
$50 shipped
Old Nov 1, 2003 | 07:07 PM
Default Re: Head Bolts (Mista Bone)
I am going to get new ones. Thanks a lot for the insights guys!
Old Nov 2, 2003 | 12:22 AM
sporkcrx's Avatar
I haven't retorqued mine yet...been about 1000 miles Maybe I'll do it this week.
Old Nov 2, 2003 | 12:39 AM
Caleb V's Avatar
If they have fluted spirals all down the shank of the bolt then reuse. If not then I would recommend buying new fluted ones. That is why Honda had a recall at one time to replace the standard style headbolts. The fluted ones are meant to be reusable.
Old Nov 2, 2003 | 05:31 AM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">if you retorque the head bolts after 500 miles and at first 3000 mile oil change, you'll never have a problem.
#90005-pm3-004
$50 shipped</TD></TR></TABLE>
hes correct
and as a second rule
never use them mroe than 3 times!
