MPFI swap...PM6 VS. PG7...worth the effort?
Old Oct 31, 2003 | 03:40 PM
subgeniusdude's Avatar
Default MPFI swap...PM6 VS. PG7...worth the effort?
I've done the MPFI swap on my 91 Civic Std and currently using a PM6 ECU...I want to try the PG7 from the old school Integra since I hear it's got a more agressive program as far as fuel and timing go.Anyone done this?I was just wondering if it's even worth doing.Only other mods are a Konig intake and Neuspeed wires.Thanks in advance!
Old Oct 31, 2003 | 04:17 PM
91civicDXdude's Avatar
i wouldn't use the PG7 on your D15B1. it will just run very very rich and stink out the tail pipe. a PM6 will run the engine rich as it is.
Old Oct 31, 2003 | 04:22 PM
USDM 4G VTEC's Avatar
Default Re: MPFI swap...PM6 VS. PG7...worth the effort? (subgeniusdude)
on my D16Z6 when i had the PM6 it ran ok and redlined @ 6800 when hot and 6400 on cold....
when i swapped for a 89 integra PG7 i noticced a whole diff world.... it redlines @ 7200 hot and 6500 cold.... and runs rich but hey its actually gives more power from 5500-7200 than the PM6
Grease Monkey's Avatar
Default Re: (91civicDXdude)
I'm interested too....
Old Oct 31, 2003 | 05:19 PM
the pm6 rev limits at 7414 rpm. your timing must've been off or something.
Old Oct 31, 2003 | 05:43 PM
My PM6 rev limit is at 7,000
Old Oct 31, 2003 | 05:53 PM
your tach is off. JParker, otherwise known as the writer of TurboEDIT has told me many times that the rev limit of the pm6 is 7414 rpm. I belive him to be correct, seeing as how he has looked at the memory locations of pm6 ROM Dump to verify that information.
Old Oct 31, 2003 | 05:56 PM
well i have come to beleive tha ti am also correct also
comparing the aftermarket tach , the vtec controller and dyno graps..... i have found out that the PM6 i had was 6800
Old Oct 31, 2003 | 09:52 PM
no it wasnt.
Old Oct 31, 2003 | 10:15 PM
Ef Whore's Avatar
I ran the pg7 on my a6. It was worth the rich smell because it offered more power and a wayyy higher redline. Worth it IMO.
Old Nov 1, 2003 | 12:13 AM
westcoastcat's Avatar
dont use the pg7, no good, use pm6 (si) , mah will rev to 7300ish, then start poppin the redline.. but with ur std have u done the mpfi,wring,ecu,si agressive cam (a6), and 5 speed si tranny, the 4 speed will kill u, trust me, evan a dx 5 spd is better,
89 std hatch, jdm vti vtec/obd1,p28,h/i/e, and no tranny..help
Old Nov 1, 2003 | 07:48 AM
91civicEX's Avatar
Default Re: (blcwsfly20)
my pm6 redlined at 6800. id like to see a video of a stock pm6 letting the engine rev up to 7414
Old Nov 1, 2003 | 08:18 AM
an ECU doesnt red line. the tach red lines. the ECU rev limits, and it does so at 7414 rpm.
As i said, your tachs are off. You cant argue against the code hard coded into the ECU ROM.
Old Nov 1, 2003 | 08:40 AM
davens's Avatar
The Honda tachs are NOTORIOUSLY inaccurate, especially at higher rpms. Being off 500 rpms off is not uncommon. Now aftermarket tachs are another matter...
Old Nov 1, 2003 | 09:30 AM
Default Re: (davens)
Thanks for the input everyone...I don't really care to rev past 7000 with the stock rods,just looking for a little more low end as nothing really happens until about 4500 and not enough grip right now to do a swap .Honda Tech recently got 211 HP from a budget boosted D16A6,so I'm sure the D15 has potentional since it's got a shorter stroke.
Old Nov 1, 2003 | 10:31 AM
89civicdx's Avatar
Default Re: (subgeniusdude)
rev limits are where you see em here "stk" means pm6
Old Nov 2, 2003 | 11:16 AM
essex's Avatar
Default Re: (Grease Monkey)
off topic anyone know the limit on a 1.5dx ecu
Old Nov 2, 2003 | 04:07 PM
EG8R's Avatar
Default Re: (essex)
Around 6800....
black0hatch
Jan 18, 2008 09:20 AM
slow91crx
14
Jan 22, 2005 06:18 PM
mar778c
Dec 28, 2004 08:32 PM
SohcVtecCrix
Sep 14, 2002 07:23 AM
USDM 4G VTEC
11
Aug 16, 2002 12:12 PM
