ECU CHIP + JACKSON CHARGER/ ZEX CAM???
Old Oct 31, 2003 | 11:55 AM
JICEK9's Avatar
Default ECU CHIP + JACKSON CHARGER/ ZEX CAM???
okay, here is the current set-up
d16y8 (stock)
jackson racing sc at 6lb
b&m fuel pump
apexi safc
header/test pipe/catback/intake
I just purchased a ecu jumper harness to convert the car from obd2b to obd1. Next to come is the complete ZEX head package for my motor (street/strip cam, springs) My question comes into play next. When parchasing a new ecu (p28) should I buy a stock one and tune it with my SAFC, or should I buy a "chipped" ecu? One reason I am considering a chip is because I would like a higher rev-limiter, lower v-tec engagement (with ajusted fuel), and a more aggressive fuel curve. I am concerned how it will all work together. (timing and stuff like that) Any advise will be helpful.
Also, if you know a good ecu tuner for a supercharged application please hook me up
thanks
Old Oct 31, 2003 | 12:33 PM
VTC_CiViC's Avatar
Default Re: ECU CHIP + JACKSON CHARGER/ ZEX CAM??? (JICEK9)
Typical "chipped" ECU's come tuned with N/A maps i.e. very aggresive timing. Buy a virgin P28 and run Uberdata or an AFC yourself.
Old Oct 31, 2003 | 12:43 PM
JICEK9's Avatar
Default Re: ECU CHIP + JACKSON CHARGER/ ZEX CAM??? (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Typical "chipped" ECU's come tuned with N/A maps i.e. very aggresive timing</TD></TR></TABLE>
that is what I was concerned about. So "vtc_civic" said no chip.
anyone else?
Old Oct 31, 2003 | 12:56 PM
maddog20's Avatar
No chip! Advance timing doesn't go well with boost. Go Hondata or uberdata like VTC_Civic mentioned before
Old Oct 31, 2003 | 01:48 PM
JICEK9's Avatar
Default Re: ECU CHIP + JACKSON CHARGER/ ZEX CAM??? (maddog20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 &raquo;</TD></TR><TR><TD CLASS="quote">No chip! Advance timing doesn't go well with boost. Go Hondata or uberdata like VTC_Civic mentioned before</TD></TR></TABLE>
how will just the Apexi SAFC do? will this be enough, or is hondata still the answer?
Old Nov 1, 2003 | 05:20 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">
how will just the Apexi SAFC do? will this be enough, or is hondata still the answer?</TD></TR></TABLE>
Old Nov 1, 2003 | 09:46 AM
JICEK9's Avatar
I have done a little checking into UBERDATA looks like some good ****. how hard is all this do do? it seems a little more then I could do on my own. (i was once fired from NOKIA because I couldn't sodier that small ****) but besides that, what ecu is best for it p28 i hope?
what would be the total cost to set-up the car with UBERDATA ?
Old Nov 3, 2003 | 07:50 AM
JICEK9's Avatar
anybody?
Old Nov 4, 2003 | 09:23 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">I have done a little checking into UBERDATA looks like some good ****. how hard is all this do do? it seems a little more then I could do on my own. (i was once fired from NOKIA because I couldn't sodier that small ****) but besides that, what ecu is best for it p28 i hope?
what would be the total cost to set-up the car with UBERDATA ?</TD></TR></TABLE>
please help...
Old Nov 4, 2003 | 11:16 AM
maddog20's Avatar
Well since you already bought the conversion harness you can just buy Hondata for around 400 bucks you need to get the boost option. Check w/ http://www.wiredspeed.com email & tell them your from H-T.com. They'll get you a killer deal.
Old Nov 4, 2003 | 12:44 PM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maddog20 &raquo;</TD></TR><TR><TD CLASS="quote">Well since you already bought the conversion harness you can just buy Hondata for around 400 bucks you need to get the boost option. Check w/ http://www.wiredspeed.com email & tell them your from H-T.com. They'll get you a killer deal.</TD></TR></TABLE>
thanks maddog, anbody have any other input?
If I were to do Hondata, how much work is it to convert so it will run a b-series if I decide to go twin cam in the future?
Old Nov 12, 2003 | 04:43 AM
JICEK9's Avatar
If I were to do Hondata, how much work is it to convert so it will run a b-series if I decide to go twin cam in the future?</TD></TR></TABLE>
come people, help me out
Old Nov 14, 2003 | 06:33 AM
JICEK9's Avatar
come people, help me out </TD></TR></TABLE>
can I please get an answer from you froced induct guys
Old Nov 14, 2003 | 06:51 AM
maddog20's Avatar
Well it will have to be a OBD2 engine to utilize the conversion harness or just use a obd1 engine w/o the harness. I mean alot depends on the engine you buy too. If it has a different ECU (P72 vs P28) they'll have a different harness you'll have to have Hondata placed in the new engines ECU. I believe this is correct
Old Nov 14, 2003 | 08:00 AM
Burke's Avatar
Banned
assuming you have an obd1, uberdata is pretty cheap. $100 for a burner and $20 worth of chips, etc assuming you have a soldering iron. the software is free!!!!
Old Nov 14, 2003 | 09:47 AM
Night_Minx
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">I just purchased a ecu jumper harness to convert the car from obd2b to obd1.
One reason I am considering a chip is because I would like a <u>higher rev-limiter</u>
Any advice will be helpful.
thanks </TD></TR></TABLE>
I lost both RPM and MPH limiters on my d16y8 when converting to D16z6 ECU.
I have no idea why.
Old Nov 14, 2003 | 09:50 AM
JICEK9's Avatar
Default Re: ECU CHIP + JACKSON CHARGER/ ZEX CAM??? (Night_Minx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Night_Minx &raquo;</TD></TR><TR><TD CLASS="quote">
I have no idea why.</TD></TR></TABLE>
that's wierd that's the p28, right?
mtber
1075
Dec 22, 2008 02:59 PM
mtber
460
Nov 18, 2008 02:35 PM
JDean6pac
Mar 19, 2007 09:43 AM
mtber
Mar 7, 2007 09:59 AM
