Jim Fab Crossmember
Old Oct 31, 2003 | 09:45 AM
sir91's Avatar
Default Jim Fab Crossmember
Is anyone out there using this crossmember on a daily driven vehicle? How do you like it? Any difference to stock? Thanks for your answers.
Old Oct 31, 2003 | 09:59 AM
CRX Si's Avatar
Default Re: Jim Fab Crossmember (sir91)
Not to jack your thread, but can you use a 92-95 rad with the jimfab? I am pretty sure you can with the z10 but i like the jimfab better...
Old Nov 2, 2003 | 03:49 PM
redzcstandardhatch's Avatar
something different
bump
Old Nov 3, 2003 | 09:04 AM
wickedcrx's Avatar
Default Re: Jim Fab Crossmember (redzcstandardhatch)
intrested on that question too come on ppl give us ur experiance
Old Nov 3, 2003 | 10:30 AM
slooogsr's Avatar
im using it on my daily driver and i like it alot......... just to warn you, you will feel every bump in the road with these bars.........
cornering is much improved and wheel hop is decreased, but im having problems getting them adjusted correctly for my setup....... i just havent had time to adjust them again due to school and work........
Old Nov 3, 2003 | 10:34 AM
slooogsr's Avatar
theres alot of things u have to consider though with ride quality.......... i have about 200k on my chasis and factory bushings and all up front........... i just installed kyb gr2's and im using eibach springs as well........
as far as tread im using 195-55 on hx wheels
Old Nov 3, 2003 | 11:11 AM
sir91's Avatar
Default Re: (sloorex)
Thanks for the reply. What are you trying to adjust? I don't get it. My set up on my car is Tokico 5-way ajustable w/eibach springs and prothane bushings all around with 94-GSR rims on 195/55.
Old Nov 3, 2003 | 01:44 PM
kid-honda's Avatar
I could have told you but the group buy for them I was on disappered overnight after the first batch, damnit.
Old Nov 3, 2003 | 05:30 PM
slooogsr's Avatar
adjusting the heim joints/radius rods........ they unscrew and are adjustable to how much load or preload you want.......
it seems like you have a good suspension setup already, i say go for it dude, its not an extremely bad ride......... it keeps ur tires planted thats for sure.
Old Nov 3, 2003 | 07:41 PM
CRX Si's Avatar
so does anyone know about using the smaller radiator?
Old Nov 3, 2003 | 07:55 PM
slooogsr's Avatar
i will eventually be using the 92-95 rad but im not sure what it involves............
from what i hear its an easy upgrade for more room using a turbo setup and can be used with the jimfab bar...........
Old Nov 3, 2003 | 08:03 PM
CRX Si's Avatar
sweet thanks
Old Nov 3, 2003 | 09:48 PM
HandCommand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloorex &raquo;</TD></TR><TR><TD CLASS="quote">im using it on my daily driver and i like it alot......... just to warn you, you will feel every bump in the road with these bars.........
cornering is much improved and wheel hop is decreased, but im having problems getting them adjusted correctly for my setup....... i just havent had time to adjust them again due to school and work........</TD></TR></TABLE>
Ahh, finally a descriptive reply from someone who actually owns and experiences the product.
Did you get an alignment after the installation? I would assume the adjustable radius rods would alter your CASTER, wouldn't it?
Old Nov 3, 2003 | 10:58 PM
ExospeedAMcrx's Avatar
Default Re: (CRX Si)
We have the Jimfab bars on several local customer's cars and they work so good at the track and the street, but we highly recommend getting an alignment if you are not familiar with adjusting them yourself.
The Jimfab bar should not be solution to be able to fit a 92-00 Radiator on your EF, its not going to work. We suggest Using the C&R "Shorty" radiator if you want a smaller radiator for your EF. The "SHorty" radiator is designed for the EF to be able to fit B series motors with big headers or if you need more space to fit a large turbo on the drivers side of the engine bay. The size is similar to the 92-00 civic radiator but is the perfect height for the EF chassis.
BTW: Jimfab 88-91 Civic/CRX is in stock and ready to ship as well as the 92-00 version
Old Nov 4, 2003 | 06:22 AM
slooogsr's Avatar
Default Re: (HandCommand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HandCommand &raquo;</TD></TR><TR><TD CLASS="quote">
Did you get an alignment after the installation? I would assume the adjustable radius rods would alter your CASTER, wouldn't it?</TD></TR></TABLE>
correct the do alter your caster and toe, as of right now i have them adjusted close to 0 load which is just having the rods turned out enough so the bolt slips right thru the bar...... i dont have access to a lift and its hard to have them adjusted farther out to see how it performs, but ppl have told me the 0 setting is the best all round..........
and i have not had an alignment yet but from what i can tell its not off by a whole lot......... im just keeping an eye on my tires as well..... I still definitely recommend these bars, daily driving is not a hassle with them.
sorry i guess i was mis-informed about the 92-95 rad......
Old Nov 4, 2003 | 09:08 AM
CRX Si's Avatar
no prob about the rad, the C&R is prolly a good deal
Old Nov 4, 2003 | 10:02 AM
Vinceg99's Avatar
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">The Jimfab bar should not be solution to be able to fit a 92-00 Radiator on your EF, its not going to work.</TD></TR></TABLE>
Hmmm? See I was told that there are 2 different Jim Fab bars for the 88-91 CRX one that you can use the 92-95 radiator and one that you cant? Also that you were able to have the front mount as well??
Old Nov 4, 2003 | 10:08 AM
91hondacrx's Avatar
Default Re: (Vinceg99)
Does anyone have a link to a site to see what the crossmember looks like? I have never heard of them and i am interested in one.
Thanks,
Matt
Modified by 91hondacrx at 8:49 PM 11/4/2003
Old Nov 4, 2003 | 11:35 AM
slooogsr's Avatar
http://www.jimfab.com
Old Nov 4, 2003 | 04:10 PM
Onesickcrx's Avatar
befor bar i could not get my car to launch past 3500 on radials nowsince bar and with camaber kit and aliment 5800 and she hooks like a charm car handles roads great very glued to ground even on 4 inch drop also good 3 inches more room with bisi header
Old Nov 4, 2003 | 08:20 PM
Default Re: (Onesickcrx)
Here's a pic of the EF style Jimfab bar:
Old Nov 4, 2003 | 09:03 PM
slooogsr's Avatar
using it on the single cam project i see..........
Old Nov 4, 2003 | 10:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloorex &raquo;</TD></TR><TR><TD CLASS="quote">using it on the single cam project i see.......... </TD></TR></TABLE>
yup yes we are.. is there anything else you would like us to use on our project car?
Old Nov 4, 2003 | 10:42 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">yup yes we are.. is there anything else you would like us to use on our project car? </TD></TR></TABLE>
Yeah what about some aftermarket rear LCA's? There was a post not too long ago and someone sells some billet ones for CRX's/Hatches but whats the big deal about them? I mean besides being lighter do you get anything else out of them? Heres the ones from the other thread. http://store.hybridgarage.com/...0007B
Old Nov 4, 2003 | 11:01 PM
we are using all the products available from SPC for the supension aligment parts from:
Front Ball joints for camber adjustment
Rear Toe adjustment
Rear Camber adustment
Rear Lower Control Arm (which comes in Polished, Red or Blue)
