b18c5 rebuild
made an expensive mistake last night. i think i misshifted not sure. 2 holes in pistons , 2 crushed spark plugs. no hole in block that i can see.wont turn over. Will i be better off rebuilding or lookin for another motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maximus »</TD></TR><TR><TD CLASS="quote">The rebuild should cost less than that and should be more powerful with the right ingredients...</TD></TR></TABLE>
i think so too.
i think so too.
If it doesn't turn over, rod might be bent or broken. And if that's the case, then you're gonna want to tear down the motor and check the walls and water jackets. I've seen lots of B-series blocks with broken rods that toasted the crank, and scratched the **** out of the main caps. But that's just one case.... you won't know until you tear down the motor and then determine how much work needs to be done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clayj »</TD></TR><TR><TD CLASS="quote">Busted out front of sleeves. small hole behind header in block. Im guessing i need a new motor right?</TD></TR></TABLE>
It looks that way
It looks that way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clayj »</TD></TR><TR><TD CLASS="quote">took the head off and the 2 & 4 pistons were gone. 4 valves in each chamber were gone too.Busted out front of sleeves. small hole behind header in block. Im guessing i need a new motor right?</TD></TR></TABLE>
It would be safe to say YES to that one.
elpiar
Dec 8, 2009 01:38 PM
