10K rev'n B18c1 build up... what you think????
Old Oct 31, 2003 | 06:57 AM
Irishweird00's Avatar
Banned
Default 10K rev'n B18c1 build up... what you think????
ok here is the cheapest bang for the buck that I could come up with....
B18c1 longblock from Hmotorsonline.com
Head:
Skunk2 Stage 3 cams
Skunk2 Cam gears
Skunk2 Ti retainers/valve springs
Ferrea Valves intake/exhaust
p&p 3 angle valve job
ARP head studs
AEBS intake manifold
J's racing CF intake
68mm TB
Header tech/hytech.... one of those $1200 headers, and Mugen twin loop exhaust.
Block
Stock bore
CTR pistons
ITR rods
APR rod bolts
Balanced and blueprinted
Tranny
B16a2 with Quaife LSD
Once the motor is build its going on my car... and I'm selling my B16a2 longlbock to get some cash.
Compression should be around 12:3 with just the pistons and 2 layer head gasket... with flat faced valves... i dunno what it would be.
What do you guys think? reliable... but powerfull right?... hell of alot cheaper than most all motor setups... but still pricey
Old Oct 31, 2003 | 07:01 AM
infamousR13's Avatar
Is it going into a 99' si?
Old Oct 31, 2003 | 07:02 AM
Banned
Default Re: (infamousR13)
yeah
Old Oct 31, 2003 | 07:10 AM
CHRIS 1.8's Avatar
Default Re: 10K rev'n B18c1 build up... what you think???? (Irishweird00)
It will hold up, depending how much your beat on your motor and maintain it.
Old Oct 31, 2003 | 07:38 AM
Archidictus's Avatar
Unceasing Measure
Default Re: 10K rev'n B18c1 build up... what you think???? (CHRIS 1.8)
What ECU program are you planning on running with that setup, and do you have an upgraded fuel pump and/or FPR in those plans? If not, I'd advise them.
I fjhlllllllllllkvu's Avatar
Chris I now Stve at Hmotoronline, how much did you pay for the B18C1 Long block only? no S&H That set up Looks Nice Like 205WHP and High 13sec in Your civic Si 99 street tires O ya get the Skunk2 stage 2 cam's and ITR valves, ITR piston tund Like 210WHP 13.7
Old Oct 31, 2003 | 09:20 AM
Banned
Default Re: 10K rev'n B18c1 build up... what you think???? (Manuel)
well i already have stage 3 cams, and ferrea valves seem good to me... so im gunna go with them.
and yes, there is alot i didnt list... such as clutch setup, fuel system, ect....
Old Oct 31, 2003 | 12:03 PM
GOLDBERG's Avatar
WHY NOT SAVE YOURSELF A FEW HUNDRED BUCKS AND GO WITH A dtr HEADER?
Old Oct 31, 2003 | 12:26 PM
Rob Dizzle's Avatar
ditch the skunk2 springs and retainers and go with the full ferrea spring/retainer setup. i think they offer better valve seats compared to oem.
much better
and lose the itr rods with ctr pistons and get lighter weight connecting rods and forger pistons like ib wiseco or CP pistons
jun3 cams might make more power up top compared to the skunk 3's
get some acl engine bearings and u should be good to go up to 10 and a lil more
i hope u have extra money for some tunign wiht a hondata or aem ems setup
Old Oct 31, 2003 | 03:08 PM
Banned
Default Re: 10K rev'n B18c1 build up... what you think???? (Bob-DC2)
True.....
Modified by Irishweird00 at 8:05 PM 10/31/2003
Old Oct 31, 2003 | 05:13 PM
Stein's Avatar
The JUN 3's will not make more power than the Skunk2 Stage 3's, from what I've read, the Stage 3's are race only or for a block that is very well put together, I would be very suprised if the JUN3's lay down more power than the S2S3.
Old Oct 31, 2003 | 05:41 PM
JDM knowledge's Avatar
Default Re: 10K rev'n B18c1 build up... what you think???? (Stein)
yeah i have heard the same with the Skunk2 stage 3's as far as them making more than Jun's stage 3. i think the stage 2 from skunk2 are near those of the Jun's stage 3. Not sure but correct me on it.
Old Nov 1, 2003 | 06:57 AM
Default Re: 10K rev'n B18c1 build up... what you think???? (JDM knowledge)
Ther is a 2WHP differenes betwen Jun3 and Skunk2 stage 2 cam's Jun make like 2more whp I seen the doyn on full built ALLMOTOR
Get Toda spring's, and Port Flow retaners, save to go 10K
Old Nov 1, 2003 | 08:34 AM
kill bill's Avatar
lose that muffler too...
Agustine Reyes
10
Oct 14, 2017 02:02 PM
hatchn1.9
15
Dec 15, 2010 02:22 PM
rsa0905
Oct 14, 2010 12:48 PM
jaydmcrx
Sep 9, 2005 07:11 AM
Driven
19
Jun 28, 2005 11:56 PM
