Help my speedometer does not work
Old Oct 30, 2003 | 05:55 PM
dohcvtecsol's Avatar
Default Help my speedometer does not work
when i accelerate my speedometer just oges crazy anybody have any ideas with what is wrong thanks
Ricey McRicerton's Avatar
Default Re: Help my speedometer does not work (dohcvtecsol)
VSS. You need a new one.
Old Oct 30, 2003 | 06:07 PM
endlesswinterco's Avatar
ur cable is starting to go bad
Old Oct 30, 2003 | 06:19 PM
5 Skware's Avatar
I missed the boat
Default Re: Help my speedometer does not work (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">VSS. You need a new one.</TD></TR></TABLE>
Probably just need a new one but it is possible that one of the pins in the VSS is just loose and causing the eratic bouncing of the speedo (it happened to me).
Old Oct 30, 2003 | 06:21 PM
Default Re: Help my speedometer does not work (EGCIV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGCIV &raquo;</TD></TR><TR><TD CLASS="quote">
Probably just need a new one but it is possible that one of the pins in the VSS is just loose and causing the eratic bouncing of the speedo (it happened to me). </TD></TR></TABLE>
Good point, go make sure that it's still plugged in good first.
Old Oct 30, 2003 | 06:23 PM
Discosteak's Avatar
Default Re: (RidinlowHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch &raquo;</TD></TR><TR><TD CLASS="quote">ur cable is starting to go bad</TD></TR></TABLE>
there is no cable
Old Oct 31, 2003 | 07:10 AM
where is the VSS. located at
andrew__g
Sep 4, 2008 05:42 AM
monney
15
Jun 22, 2007 03:48 PM
Mr. Giggles
Aug 11, 2006 05:21 AM
SlippylesKB
20
Oct 18, 2003 04:32 PM
speedracer33
28
Jul 23, 2003 06:28 PM
