Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
*whump*whump*whump*whump*
Old Oct 30, 2003 | 02:00 PM
.RJ's Avatar
.RJ
Default *whump*whump*whump*whump*
Alright... before i spend any money i'd like an opinion on this.
Got a vibration (felt in the steering wheel and shifter) accompanied by an audible "whumpwhumpwhump" when i accelerate, in my 91 integra (now relegated to daily driving and hauling **** around).
- It is not present when i first drive the vehicle
- Gets worse the longer i drive it
- It only manifests itself under acceleration
- Under deceleration or cruise there is no 'whumping'
- If i am accelerating and immediately depress the clutch the 'whumping' vanishes
- Under right hand turns the 'whumping' also vanishes
- Sounds like its coming from the driver's side front
I have rotated the wheels, no change. I have also inspected both sides of the suspension and dont find anything torn, leaking, spewing, or with excessive play.
All of this leads me to believe its the driver's side axle since the noise is not present when coasting and not a wheel/tire/wheelbearing issue....
Thoughts before i pick up a reman from advance auto tomorrow and have at it?
Old Oct 30, 2003 | 02:01 PM
Footwork's Avatar
Default Re: *whump*whump*whump*whump* (.RJ)
Torn CV was my bet, but you said you inspected everything.
Old Oct 30, 2003 | 02:02 PM
.RJ's Avatar
.RJ
Default Re: *whump*whump*whump*whump* (Primo.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">Torn CV is my bet.</TD></TR></TABLE>
The Boots are in fantastic shape.... although i have no idea what lurks underneath them. And thats where i'm thinking the problem lies.
Old Oct 30, 2003 | 02:07 PM
Eee Pee's Avatar
I'm on my second Advanced Auto reman'd axle.
Both have that nasty vibration around 65 mph, and sometimes flooring it.
Food for think?
And I've had the wheels balanced three times.
For a bit more you may want to consider an OEM axle.
Honda parts guys (friends, too) say, "They do a better job."
Old Oct 30, 2003 | 02:09 PM
.RJ's Avatar
.RJ
Default Re: *whump*whump*whump*whump* (Eee Pee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eee Pee &raquo;</TD></TR><TR><TD CLASS="quote">For a bit more you may want to consider an OEM axle.
Honda parts guys (friends, too) say, "They do a better job." </TD></TR></TABLE>
Wholesale cost is $300+. List is up near $600. Retail is about $460.
I was planning on getting IAS on the horn tomorrow though. Problem is, the 90-93 integra axles work fansastic for a b-series in a EG-hatch swap.
Old Oct 30, 2003 | 02:10 PM
Catch 22's Avatar
Spun Bearing.
Put the car on stands and run the motor. If the "whump" is coming from the back side of the oil pan...
Our Neon did the same thing when it spun a bearing. We thought it was a halfshaft.
Old Oct 30, 2003 | 02:12 PM
Eee Pee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Wholesale cost is $300+. List is up near $600. Retail is about $460.
Wow. He said about $150...Huh.
Oh, and a spun bearing is not what I wanted to hear.
Old Oct 30, 2003 | 02:13 PM
.RJ's Avatar
.RJ
Default Re: *whump*whump*whump*whump* (Catch 22)
The 'whumping' does not occur when accelerating the engine with the clutch in, on the stands or while the engine is hot and the car has been sitting or while accelerating while turning right.
Old Oct 30, 2003 | 02:23 PM
johng's Avatar
Does the sound get faster as the wheels turn faster?
Old Oct 30, 2003 | 02:24 PM
.RJ's Avatar
.RJ
Default Re: *whump*whump*whump*whump* (johng)
yes
Old Oct 30, 2003 | 02:31 PM
Greyout's Avatar
I would bet the farm that its the axle, even if the boot looks healthy. Most likely the inboard CV joint. Happened to several local cars with the same symptoms, including my own.
Replace the axle on the side that is ok when you turn that direction.
For example - if you turn right and it goes away, the problem is on the right side.
Old Oct 30, 2003 | 02:33 PM
.RJ's Avatar
.RJ
Default Re: *whump*whump*whump*whump* (Greyout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout &raquo;</TD></TR><TR><TD CLASS="quote">For example - if you turn right and it goes away, the problem is on the right side.</TD></TR></TABLE>
Hmm. Thats not where the problem appears to be coming from - although wheelbearings and axles can be hard to diagnose that way.
I wouldnt have even thought about that. Thanks
Old Oct 30, 2003 | 03:04 PM
Todd00's Avatar
I said I don't want a title!
You guys need to stop buying the low-cost Advance Auto axles. Buy the brand new ones for about $20 more. Much better of an axle and same warranty.
Old Oct 30, 2003 | 03:44 PM
gotocrx's Avatar
Default Re: *whump*whump*whump*whump* (Todd00)
We chased a vibration exactly as you describe for two weekends in our 91 integra. We dismissed the CV because it was BRAND new. The vibration kept happening. Finally the left front wheel studs sheered off. We thought "Oh! it was the studs the whole time!" Wrong. On the second sunday our perfectly brand-new, no boot tear CV joint ex-PLODED . Replaced, problem gone. The weird thing is it was on the inboard joint. we must have damaged it on the way in.
That poor car spent alot of time behind a tow truck that weekend
Old Oct 30, 2003 | 03:48 PM
Solo2Vtec's Avatar
20 more where? I got two rebuilt axles for 100. But to be honest I now have a new vibration. When can I get OEM axles for cheap?
Old Oct 30, 2003 | 04:01 PM
.RJ's Avatar
.RJ
Default Re: *whump*whump*whump*whump* (Solo2Vtec)
http://www.partsamerica.com/Se...+Axle
There are "remans" and "new" listed.
Unfortunately, the remans are in stock at my local autozone and the new are not.
Old Oct 30, 2003 | 04:17 PM
Todd00's Avatar
Advance Auto sells GCK and CCT axles. I'm not sure which ones were the new ones, but the guy behind the desk should be able to show you. True that the new ones need to be ordered, but it was only a day wait for me.
And let me repeat, do not buy the cheapo reman units. Spend the extra $20 for the new ones.
Old Oct 30, 2003 | 04:25 PM
jeimport's Avatar
It is 100% driveshaft.....I will even go as far as to gaurantee that it is your cv. Unfortunatly I have a good amount of experience with bad cv's.....from my H1 car.
Old Oct 30, 2003 | 05:06 PM
kb58's Avatar
Banned
Default Re: *whump*whump*whump*whump* (jeimport)
CV or wheel bearing.
Old Oct 30, 2003 | 05:44 PM
CRX Lee's Avatar
Default Re: *whump*whump*whump*whump* (kb58)
I'll jump on the inner CV bandwagon.
Old Oct 30, 2003 | 05:58 PM
Pancake Titties's Avatar
Default Re: *whump*whump*whump*whump* (CRX Lee)
Yea, I agree. Inner joint. I had this problem on my CRX with B16, did the same thing. Get under the car and check for play in the joint.
Old Oct 30, 2003 | 06:04 PM
Dan GSR's Avatar
Default Re: *whump*whump*whump*whump* (Pancake *******)
yeah...sounds like axles
Old Oct 30, 2003 | 06:10 PM
Todd Reid's Avatar
Default Re: *whump*whump*whump*whump* (Dan GSR)
i concur with JEimports 100%.
my inner CV went bad driving back from the Glen two years ago. exactly the same symptoms you described. to a tee.
crawl under the car and try twisting the shaft. you will find excessive play in the inner CV joint.
good luck RJ.
see you at summit point!
Old Oct 30, 2003 | 06:28 PM
.RJ's Avatar
.RJ
Default Re: *whump*whump*whump*whump* (Todd Reid)
out comes the BFH tomorrow. excellent.
Old Oct 31, 2003 | 07:15 AM
Honda318dx's Avatar
I'm late, but I bet the farm on Inner CV..
