FS: ATI RADEON 9600
Old Oct 30, 2003 | 01:16 PM
sloaccord96's Avatar
Default FS: ATI RADEON 9600
Hey guys, I bought this card during the beginning of September but now I just use my GeForce so I don't need this high-powered video card, bought new at NewEgg for $120.
ATI 9600 RADEON
8X AGP BUS
128MB DDR RAM
4 parallel rendering pipelines
2 parallel geometry engines
128-bit DDR memory interface (64-bit on RADEON™ 9600 SE)
AGP 8X support
SMARTSHADER™ 2.0
Programmable pixel and vertex shaders
16 textures per pass
Pixel shaders up to 160 instructions with 128-bit floating point precision
Vertex shaders up to 1024 instructions with flow control
Multiple render target support
Shadow volume rendering acceleration
High precision 10-bit per channel frame buffer support
Supports DirectX® 9.0 and the latest version of OpenGL®
SMOOTHVISION™ 2.1
2x/4x/6x full scene anti-aliasing modes
Adaptive algorithm with programmable sample patterns
2x/4x/8x/16x anisotropic filtering modes
Adaptive algorithm with bi-linear (performance) and tri-linear (quality) options
HYPER Z™ III+
Lossless Z-Buffer compression (up to 24:1)
Fast Z-Buffer Clear
TRUFORM™ 2.0
2nd generation N-Patch higher order surface support
Discrete and continuous tessellation levels per polygon
Displacement mapping
VIDEOSHADER™
Seamless integration of pixel shaders with video
FULLSTREAM™ video de-blocking technology
Noise removal filtering for captured video
MPEG-2 decoding with motion compensation, iDCT and color space conversion
All-format DTV/HDTV decoding
YPrPb component output*
Adaptive de-interlacing and frame rate conversion
Dual integrated display controllers
Dual integrated 10-bit per channel 400 MHz DACs
Integrated 165 MHz TMDS transmitter (DVI 1.0 compliant)
Integrated TV Output support up to 1024x768 resolution
Optimized for Pentium® 4 SSE2 and AMD Athlon™ 3Dnow!
PC 2002 compliant
90$/OBO
Old Oct 30, 2003 | 01:19 PM
b18bturbo's Avatar
Default Re: FS: ATI RADEON 9600 (sloaccord96)
does it have the tv tuner built it in ...
Old Oct 30, 2003 | 01:27 PM
dom93hatch's Avatar
Default Re: FS: ATI RADEON 9600 (b18bturbo)
Damn good deal
wish i had money now...
Old Oct 30, 2003 | 01:34 PM
ek_david's Avatar
naw it doesn't, the All-in-wonder has the TV turner in it and should cost a bit more.
Old Oct 30, 2003 | 01:40 PM
Sorry no TV-tuner hell I'd keep it if it was the AIW !!! ^_^
It has DVI (flat panel support), VGA (normal CRT monitors) and S-Video out.
gloria2323
Jan 3, 2012 03:44 PM
Stillapfg
Nov 29, 2009 12:47 PM
JoeB18R
Feb 25, 2005 10:11 AM
