Oil pan removal...
Old Oct 30, 2003 | 12:50 PM
baggelis's Avatar
Default Oil pan removal...
how the hell can I get the out the screw that is behind the the metal piece that holds the muffler..... and also how do I get out the two screws at the left side,,,, the ones that are hidden....
thanks...
Old Oct 30, 2003 | 12:57 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Oil pan removal... (baggelis)
You have to remove the flywheel cover..
Use a "universal-joint" so you can hit it from an angle
or just remove the bracket that is in your way..
Old Oct 30, 2003 | 02:26 PM
EL Vap133's Avatar
stock motor? My B16 oil pan was easy to remove.
Old Oct 30, 2003 | 02:30 PM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baggelis &raquo;</TD></TR><TR><TD CLASS="quote">how the hell can I get the out the screw that is behind the the metal piece that holds the muffler..... and also how do I get out the two screws at the left side,,,, the ones that are hidden....
thanks...</TD></TR></TABLE>
Take off the flywheel cover....and anything else that is in the obvious way of the pan, depending on your motor. Swivels are your friend.
chris_c
Dec 27, 2007 12:40 PM
shbrown
Jan 28, 2006 03:46 PM
Cuong-nutz
Nov 4, 2005 10:27 PM
BANting
Dec 21, 2004 08:26 PM
02 coupe
Jun 25, 2003 01:56 PM
