Opinions... on my first manifold......
Old Oct 30, 2003 | 11:59 AM
G's Avatar
G
Default Opinions... on my first manifold......
Besides welding in need of help, what do you think? I wanted a straight passage through to the turbo. When looking through the turbo flange, I can see all the runners directly. I have to use a mini radiator, but it is my first mani. I hope that it holds up and performs as well........
Old Oct 30, 2003 | 12:04 PM
Ben Huynh's Avatar
Default Re: Opinions... on my first manifold...... (G)
Interesting design. I like your welds though.
Old Oct 30, 2003 | 12:06 PM
Gravy's Avatar
Default Re: Opinions... on my first manifold...... (ben@importparts.com)
yeah i would like to see you collector. it different and nice
Old Oct 30, 2003 | 12:08 PM
ScottEK's Avatar
Why is your turbo so scared of your block?
Mine is similar and it made for a lot of problems, radiator etc.
Construction of the manifold looks very nice.
VTECsam's Avatar
Welds look ok... what's the gauge on the piping? Get her on the dyno and show us some numbers, good luck
Old Oct 30, 2003 | 12:13 PM
Gravy's Avatar
Default Re: Opinions... on my first manifold...... (VTECsam)
looks like you are going to need a nice support on it to.
Old Oct 30, 2003 | 12:16 PM
Muckman's Avatar
Moderator in Chief
we dont need no stinkin' radiators.
Old Oct 30, 2003 | 12:18 PM
graphic's Avatar
that **** looks RIGHT!
i love the DP
Old Oct 30, 2003 | 12:25 PM
G's Avatar
G
Thanks for the nice comments. I just got the welding machine in Aug and have been practicing whenever I could. I am still trying to figure the bracing, but there will be one or some. The collector isn't as nice as I'd like, a little rough, but there are some provisions below the #2-3 runners boxed into the t3 flange and the WG port. All in all, I am hoping for good spool on this 60-1 at about 12psi. I have a thickish civic radiator, so we'll see about it handling the load....
Thanks again, keep them comments coming.....
Old Oct 30, 2003 | 12:30 PM
Phoenix GSR's Avatar
I think it looks good! on doing your own design
Old Oct 30, 2003 | 01:26 PM
99integralsturbo's Avatar
Default Re: Opinions... on my first manifold...... (Phoenix GSR)
looks really nice, very original design any pics of where the WG port is
Old Oct 30, 2003 | 01:29 PM
NCHATCH's Avatar
i think your weld are looking great man, thums up, but please make sure your turbo is right side up, before you hook up the oil lines, i could be wrong but it looke dupside down
Old Oct 30, 2003 | 01:39 PM
TeStUdO's Avatar
Default Re: (NCHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCHATCH &raquo;</TD></TR><TR><TD CLASS="quote">i think your weld are looking great man, thums up, but please make sure your turbo is right side up, before you hook up the oil lines, i could be wrong but it looke dupside down</TD></TR></TABLE>
The turbo is clocked, also G will you make me a down pipe???
Old Oct 30, 2003 | 01:40 PM
TeStUdO's Avatar
Old Oct 30, 2003 | 02:08 PM
alpha's Avatar
I agree with a couple comments. The welds don't look that bad especially for your first manifold. I also would like to see the collector. Looks like there is allot of weight on the middle/end of the manifold due to the turbo being that far forward (not saying it's too far forward though).
Old Oct 30, 2003 | 03:00 PM
PM-Performance's Avatar
Default Re: Opinions... on my first manifold...... (0x64)
i think it look pretty decent, i would be worried about the weight on the runners like that though, maybe it wont be a prob, but something to think about. i like the design though.
Old Oct 30, 2003 | 03:52 PM
norcalcrx's Avatar
Nice to see something different. Please post results when you get them
Old Oct 30, 2003 | 04:09 PM
egturbo's Avatar
looks awesome.. y dont u clock ur turbo down? u made that urself? i wonder how its gonna perform good luck.. let us know how it goes
Old Oct 30, 2003 | 04:13 PM
Rhman19's Avatar
Default Re: Opinions... on my first manifold...... (egturbo)
Nice job. I agree with the others about supporting the turbo. But very good especially for you first mani, keep up the good work.
Old Oct 30, 2003 | 05:40 PM
boostin b16's Avatar
Default Re: Opinions... on my first manifold...... (Rhman19)
looks good
Old Oct 30, 2003 | 05:56 PM
G's Avatar
G
Default Re: Opinions... on my first manifold...... (boostin b16)
Thanks alot guys!!! I am pretty excited about the manifold, but good tuning and a few hours on the dyno would be the perfect "next step". As far as the turbo clocking/positioning, I am going to finish the dp-exhaust then need to find a good/cheap IC. I am looking towards an up/down IC as big as the civic radiator, but in front of the turbo. I am trying my best to keep IC piping short as heck.
Next fabrication challenge is the intake mani. I have the pipes and sheetmetal, just need to finish up the turbo/piping side of things.
There is going to be a 1/2" rod from the bottom of the block up towards the t3 flange for bracing, I am a big fan of bracing, hehehehe. I've had experiences with drag manifolds and hope bracing will keed the weight off the head/exmani bolts....
I'll keep all informed on its progress!!!!!
Old Oct 30, 2003 | 06:13 PM
m R g S r's Avatar
Looks really good, what kind of welder do you have? I am considering buying a welder.
Old Oct 30, 2003 | 06:17 PM
5 Skware's Avatar
I missed the boat
Looks really good for a first manifold I wish I had a welder
Old Oct 30, 2003 | 07:08 PM
hpfsi's Avatar
Nice work! Honestly your welds look pretty darn good for the most part. Be sure to post some dyno plots asap!
Old Oct 30, 2003 | 07:34 PM
egturbo's Avatar
get that **** patented
