has anyone ever had a problem with...
Old Oct 30, 2003 | 06:41 AM
hicamjunkie's Avatar
Default has anyone ever had a problem with...
has anyone ever had a problem with the Beaks mounting kit for the 22mm OE type R rear sway bar on an integra or civic. Any ripping out the center mounts on a real racing application (or even street for that matter). any info on this products durabilty would be greatly appriciated.
Old Oct 30, 2003 | 01:23 PM
Default Re: has anyone ever had a problem with... (hicamjunkie)
anyone?
Old Oct 30, 2003 | 05:24 PM
Kendall's Avatar
Why not just buy a 22mm aftermarket sway bar and not have to worry about a mount kit.
Old Oct 31, 2003 | 07:18 AM
Default Re: (dc231)
cost mainly, the comptech bar with tie is $380 or so. i have a progress bar now and the center mounts work fine but i've broken the end "L" brackets twice now. just looking for a good replacement that will hold up to RR use, i've heard the beaks kit works fine for raod use and mild RR use (if there is such a thing as mild RR use ) but i've heard of it failing too with real serious set ups (500lbs+ springs and R compound tires)
don't know what to do...
jonesvirs
Suspension & Brakes
16
Dec 8, 2010 09:00 AM
spikerockz
Nov 10, 2005 08:06 AM
jaydmcrx
Jun 13, 2004 04:10 PM
greebler
11
Feb 11, 2003 07:01 AM
StinkyTofu
Jul 17, 2002 05:47 AM
