JDM SRS steering wheel Horn?
Old Oct 30, 2003 | 04:10 AM
CTR94Joes's Avatar
Default JDM SRS steering wheel Horn?
I found this link up here but it's for a JDM Non-SRS steering wheel. https://honda-tech.com/zerothread?id=273474 Does anyone know if I can use these instructions to get my JDM SRS horn to work the same way......
Old Oct 30, 2003 | 04:34 AM
MADEinJAPAN's Avatar
Default Re: JDM SRS steering wheel Horn? (CTR94Joes)
It should just plug in...if it does not, then just change the plug so it will.
What car do you have, and what wheel do you have?
My friend has a 96 Integra..he got the JDM SRS ITR wheel and everything just plugged in. Took like 10 min.
Old Oct 30, 2003 | 06:06 AM
CTR94Joes's Avatar
Default Re: JDM SRS steering wheel Horn? (MADEinJAPAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADEinJAPAN &raquo;</TD></TR><TR><TD CLASS="quote">It should just plug in...if it does not, then just change the plug so it will.
My friend has a 96 Integra..he got the JDM SRS ITR wheel and everything just plugged in. Took like 10 min.</TD></TR></TABLE>
I got a 94 Civic with the JDM ITR SRS wheel. I had it on the car for about a year now but I never could figure out how to get the horn to work.... I just came across this link like two days ago, so i'm looking to see if anyone knows if this can be done to a SRS JDM steering wheel...
Old Oct 30, 2003 | 03:52 PM
Can you find the horn plug on the steering wheel/airbag? Then just find the horn wire/plug coming through your SRS harness. On my 96 EK it was a single blue wire. I just connected the two. You might have to solder the wire or something just find the two wires and connect them.
natman316
Apr 13, 2011 10:26 PM
floatfisher
May 16, 2008 09:28 AM
tremor86
Nov 14, 2004 06:52 PM
DC2chik
May 22, 2003 03:18 PM
98R-1144
May 10, 2003 06:32 PM
