PC Based Engine Management
I was reading through turbo mag and saw an ad for PC Programable ecu's/engine managment systems. Venom nitrous systems are also adjusted via serial cable to your pc. The systems i saw in Turbo was from Haltech. Does anyone know any other companies that make these types of products. Rather than having a bunch of piggy back systems, just one big one. Thanks
Vince
Vince
One really good system is to use a Hondata Stage 4 ECU modification and a Racelogic Real-time EPROM emulator. This allows you to reprogram the ECU literally while the car is running.
Here's the page for the Hondata Stage 4: http://www.hondata.com/stage4.html . If you browse around the site a little you will see the rest of their stuff. Make sure you look under the ROM Editor section.
Here's the page for the Racelogic EPROM Emulator: http://www.racelogic.co.uk/ . Just click the link on the left side that says 'Chip Tuning Tools'.
I've been doing a little research on this, so if you have any other questions, I MIGHT be able to answer them.
[Modified by spyder, 9:17 AM 9/6/2001]
Rspec CX
Oct 1, 2005 08:57 AM
