some Frankenstein idea..I need your comments!
Old Oct 29, 2003 | 09:07 PM
Nathan007's Avatar
Default some Frankenstein idea..I need your comments!
I have a 1994 accord v-tec, and i was wondering if its possible and how much modification it would take, to fit a h22 head , and just keep my block. I know i would have to change the ECU, and maby the manifolds.. But physically, does it fit? And for the timing belt ?
Just some idea popping out, thanks for help!
Old Oct 29, 2003 | 09:45 PM
singlecamrocket's Avatar
Default Re: some Frankenstein idea..I need your comments! (Nathan007)
what is the abreviation for your accord block. I am not familiar with the accord engines. if it is not H you r more likely than not sol. post what the engine code for it.
Old Oct 30, 2003 | 06:56 AM
noble4ws's Avatar
ive heard its been done but its unreliable and expensive as hell, better off just doin an h22 swap
Old Oct 30, 2003 | 10:49 AM
Nathan007's Avatar
Default Re: (noble4ws)
its a f22
Yeah probably the whole kit would be just plain simpler
Old Oct 30, 2003 | 06:24 PM
Default Re: (Nathan007)
definitely gonna be a pain, just go with a gsr or h22 swap. save time, trouble and money
Old Oct 30, 2003 | 08:23 PM
dfoxengr's Avatar
Default Re: (crvtec00)
GSR swap in an accord come on now..u know better
Old Nov 4, 2003 | 04:13 AM
1700anddroping's Avatar
Default Re: (hybridvteceg)
yes the f22 head will fit with slight modification.there are several advantages to doing this.one it is not exspensive as previously stated.i know i have done it.
reliability is not and issue.if its already vtec do the mod on the block NOT head and the water pump switch pullies any machine shop can do it.bore the water pump hosuing on the block to the size of the h22 tube.
so weigh the cost hmmmmmmmmmmm!!!!!!!!!!!!!!!!! 250 tops against 3-3500 h22 22-2800.now ask your self where can you put that extra money.
DannyBoy310
Apr 16, 2012 04:07 AM
howyoudo
Aug 30, 2007 03:54 PM
Libertariat
Aug 18, 2005 07:00 PM
vybez
Nov 2, 2003 04:23 PM
dav_id03
May 6, 2003 09:02 AM
