High rev????? Problem??
When I start my car it revs high while warming up. After a few minutes I come to stop and the rpm comes down to 2000 rpm and stays there for a few secs.
Then it goes to 800 rpm. After the car is completely warmed up the car runs normally. Why does it get stuck around 2000 rpm. When I tap the gas it goes up then falls and holds to 2000 rpm. Then it goes to 800 rpm.
It never did this before
mine also does that, i think its just cold starting..im assuming its normal because the idle drops down too 750rpm-800rpm...everything is fine after that
