fully built Turbo B Series 95 Civic Coupe for sale OR TRADE! 8Pix
Strut Tower Brace
Lowered 2 1/4 inches
Progress Camber Kit
Aftermarket Struts
Konig Wheels with Kumho Tires
3 Auto Meter Gauge Pods on the left piller
3 2 5/8" Gauges Tach, Boost, Oil Pressure
MSD 6A Ignition Amplifier
MSD Blaster SS Coil
Apex-I Turbo Timer
Apex-I AVC-R
Upgraded Motor Mount Inserts
Upgraded SI Radiator
MSD Plug Wires
88-91 JDM B16A
91 Integra LS Trans
Full custom 3" Exhaust from turbo back with 3" tip
3" downpipe
ACT Street/Racing Clutch 6 puck disk
Hondata ECU with boost upgrade
4 440CC RC Injectors
Spearco Intercooler
T3/T4 Turbo
HKS Blow Off Valve
Tial WasteGate
Open Dump Tube
Crower Titanium Retainers
Crower Dual Valve Springs
ARP Head Studs
JE Custom Integra Type R Pistons
JE Piston Rings
Eagle Connecting Rods
Darton Ductile Iron Sleeves
Pro Drive Oil Pump Gears
GSR Oil Pump/Housing
Chassis has 165K the motor is just about to turn 10K miles I drive the car everyday "unless its really nice then I ride the bike"
engine is built to handle 500+ WHP last dyno run "posted up top" it put down 253WHP only because of having no fuel "440cc injectors" that was at 11PSI
since theres not enough fuel to feed the motor we have most timing over 4K taken out there for it stops making power past 4K "as you can see in the dyno chart" with timing added and fuel running the same boost it shuold put down an easy 320-340WHP but why stop at 11PSI if theres enough fuel you can bump it up to a bar and lay down 380-400WHP at that range the T3/T4 is pretty much maxed out
I have over 25K total in this car! I was asking 15K OBO but now Im asking 12K!!! once again that is <U>OBO</U> and Im also willing to take trades + cash or a straight up trade if the car is worth somewhere in the area of what Im asking
engine swap was done by http://www.crxguru.com
engine built by http://www.tempestracing.com
I also have some videos if you want them
P.S even with timing taken out check out how much torque/hp my car puts down at 4K when Im out playing around for the most part I leave the car in 4/5th gear since it has so much torque
and people say B16s suck when it comes to torque
my AIM is jeffie7 and my e-mail is jeffie7@hotmail.com
Jeff
Modified by jeffie7 at 6:00 PM 11/8/2003
Modified by jeffie7 at 6:03 PM 11/8/2003
I forgot to list that it also comes with
Stock DX motor/tranny both in great cond new timing belt/water pump not long before being pulled
2 extra exhaust systems "stock" and a 2.5" cat back
2 cats ones a 2.5" landspeed racing cat the other is the stock cat
2nd downpipe with closed loop dumptube
extra LS tranny
Kenwood MP3 player 4 speaker system with sub also does XM or the name "I never use it I have mp3 cds
Im also giving with the car a 2nd set of wheels with almost new rubbers about 1500 miles on them
as with many many more parts
extra LS tranny
"Im also giving with the car a 2nd set of wheels with almost new rubbers about 1500 miles on them
King-Kong
Dec 17, 2004 06:24 AM
King-Kong
Dec 2, 2004 09:09 PM
jeffie7
Dec 1, 2003 09:34 PM
