ITR strut brace...
Old Sep 5, 2001 | 06:30 PM
crookedletterd's Avatar
New User
Default ITR strut brace...
okay, i was screwing in the bolts and they were not tight at all and then all of a sudden snap! the bolt broke in 2. now i dont want to tighten the others tight because i dont want that to happen. if you have a ITR strut brace did you tighten the bolts until they couldnt tighten any more??? mine is on tight but the bolts arnt tightend until they dont turn.
Old Sep 5, 2001 | 10:45 PM
2005 TSX's Avatar
Default Hmmm...
Are we talking about the front strut bar? When I got my original Type-R bar, I tightened the bolts down until they were tight. Probably as tight as the stock gsr bar was. Never had a problem, yet.
Old Sep 5, 2001 | 10:48 PM
GZR4DR's Avatar
Default Re: Hmmm... (2001 Integra GSR)
Well you can hammer the stud through the bottom and run a regular bolt and nut to hold the bar on. It should never break in half unless your putting all of your strength into it.
You will probably have to remove the wheel liner to pull the stud out of the bottom side.
Old Sep 6, 2001 | 03:20 AM
troy00gs's Avatar
New User
Default Re: ITR strut brace... (integls98)
According to the Helms service manual, you should torque the bolts to 16 lbs. I thought that was pretty low but the manual should be crrect.
Old Sep 6, 2001 | 03:46 AM
yaksplat's Avatar
Default Re: ITR strut brace... (troy00gs)
a lot of torques seem kind of low in the manual
that's because a good portion of the bolts are in shear as opposed to in tension or torsion. If there's no load on the head of the bolt, then there's no reason to torque it up. It's also a way to save money for the manufacturer. Why buy a bolt that can handle a lot of tension if it's used in shear.
R-gonaut
Dec 5, 2011 02:41 PM
spoolude
Sep 18, 2004 11:53 AM
FitCRX
Mar 1, 2003 03:57 PM
satintegra
Jun 12, 2002 07:44 AM
J28S
Mar 10, 2002 07:33 PM
