couple of questions
Old Oct 29, 2003 | 02:00 PM
Origin's Avatar
Default couple of questions
i want to buy some earls stainless steel brake lines but they list them for 89 to 91. will these fit my 88 crx hf? also, someone told me to look into getting hp+ brake pads. are axxis MM pads about the same or better? thanks.
Old Oct 29, 2003 | 03:24 PM
EL Vap133's Avatar
Default Re: couple of questions (Origin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">i want to buy some earls stainless steel brake lines but they list them for 89 to 91. will these fit my 88 crx hf? also, someone told me to look into getting hp+ brake pads. are axxis MM pads about the same or better? thanks.</TD></TR></TABLE>
Yes they will fit...
Old Oct 29, 2003 | 07:39 PM
Origin's Avatar
Default Re: couple of questions (EL Vap133)
alright, im glad to hear that they will fit. also can anyone give me some info on whether or not axxis pads are equal, better, or crappier than hp+ pads. thanks.
Old Oct 29, 2003 | 08:25 PM
ThatRicerDaniel's Avatar
if i may offer a suggestion. if your planning on doing some suspension upgrades you should think about upgrading to si suspension before you start adding aftermarket parts just to optimize the money your spending.
Old Oct 29, 2003 | 09:32 PM
Origin's Avatar
Default Re: couple of questions (NitrousDreamz)
well with the swap im doing right now im going to need the si hubs, what else would i need to be able to do what you suggest.
Old Oct 30, 2003 | 09:38 AM
Origin's Avatar
bump
Old Oct 30, 2003 | 09:45 AM
Vinceg99's Avatar
Well you could also do the Rear disc swap. And you could add the Si rear LCA's and then add a stock Si sway bar as well.
Old Oct 30, 2003 | 06:37 PM
Origin's Avatar
Default Re: couple of questions (Vinceg99)
id like to keep my crx hf drums. weight issues.
Vuer
Jul 27, 2010 07:49 PM
B serious
Honda S2000
23
May 1, 2007 05:23 PM
JeremyL
Apr 6, 2006 02:34 PM
Origin
15
Feb 10, 2004 02:45 PM
