diy piston tool for rear brake calipers?
whatever fits inbetween the +
big *** screwdriver (using the shaft of the screwdriver), a wrench, yadda yadda yadda.
edit - just watch the seals around the piston.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super7 »</TD></TR><TR><TD CLASS="quote">allen wrench
are you sure this works?
</TD></TR></TABLE>are you sure this works?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">
are you sure this works? </TD></TR></TABLE>
yes
yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thk »</TD></TR><TR><TD CLASS="quote">whatever fits inbetween the +
edit - just watch the seals around the piston.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock »</TD></TR><TR><TD CLASS="quote">the tool costs like 5 bucks
and a trip to ricer hq.
</TD></TR></TABLE>and a trip to ricer hq.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC »</TD></TR><TR><TD CLASS="quote">or you can use a pair of needle nose pliers... expand them slightly and turn away. worked for me.</TD></TR></TABLE>
Just did a rear break change on my friend's GSR.. The spatula trick didn't work because the piston was hard to twist. After getting it twisted in a little more, it was easier to turn. We had to buy the tool to turn the piston.
The other side was so damn easy to turn. The spatula would have worked on that one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dk127 »</TD></TR><TR><TD CLASS="quote">Yea jeez, the tool is so damn cheap...</TD></TR></TABLE>
i understand the tool is cheap... but if i already have a tool or item that will work, why would i go out and buy the tool. youre a tool.
I used a putty knife (a bit thicker and stiffer than a spatula) and it worked fine. As stated, watch to make sure the seals aren't ripping or being punctured by the pointy ends of the whatever-tool-you-decide.
