Ls/Vtec motor $1000. b16 head b18a block LOW BALLER WELCOME
Old Oct 29, 2003 | 01:05 PM
untitled's Avatar
Default Ls/Vtec motor $1000. b16 head b18a block LOW BALLER WELCOME
b18a block decked
pr4 rods reconditioned
pr4 pistons
hastings rings
ARP gsr headstud kit
3-ply steel HG
b16a head resurfaced
ARP rod bolts
ACL bearings
Earls 4an line for vtec.
earls plug in head for to plug vtec oil hole
gsr timing belt
b16 water pump
no dizzy.
theres one catch. it threw a bearing 200 miles after initial startup. it was overheating so i think it was a bearing that was too tight.
Old Oct 29, 2003 | 01:08 PM
untitled's Avatar
Default Re: Ls/Vtec motor $1000. b16 head b18a block LOW BALLER WELCOME (Vetter)
trades are welcome. i need a Dseries turbo mani with t3 flange, 16' wheels.
id also take a non-running POS s13 240!!!
Old Oct 29, 2003 | 02:05 PM
NJcoupe's Avatar
what color are the slips? PM me
Old Oct 29, 2003 | 02:22 PM
eg ferio's Avatar
where r u located at?
Old Oct 29, 2003 | 05:55 PM
untitled's Avatar
Default Re: (eg ferio)
fort wayne indiana and willing to ship at buyers expense
Old Oct 29, 2003 | 07:06 PM
untitled's Avatar
bump
Old Oct 29, 2003 | 08:31 PM
Motor-Tek's Avatar
bump for a good seller
Old Oct 30, 2003 | 10:34 AM
untitled's Avatar
Default Re: Ls/Vtec motor $1000. b16 head b18a block LOW BALLER WELCOME (Motor-Tek)
thanx man.
Old Oct 30, 2003 | 02:07 PM
lucky one's Avatar
$400 for the longblock?
Old Oct 31, 2003 | 08:59 AM
untitled's Avatar
Default Re: Ls/Vtec motor $1000. b16 head b18a block LOW BALLER WELCOME (lucky one)
come on now. i could get $400 for the head alone.
Old Oct 31, 2003 | 09:56 AM
Green JDM-R's Avatar
what happened to the integra this was in???
Old Oct 31, 2003 | 10:15 AM
untitled's Avatar
Default Re: (DreamType-S)
gone. sold. bye bye. good riddance. someone gave me cash on the spot one day.
Old Nov 1, 2003 | 04:47 AM
untitled's Avatar
Old Nov 1, 2003 | 08:12 AM
eg ferio's Avatar
have amy idea how much is shipping to miami,fl,33126?
Old Nov 1, 2003 | 12:01 PM
untitled's Avatar
$300-$350
Old Nov 1, 2003 | 01:02 PM
untitled's Avatar
for $300 it could be runngin again.
Old Nov 2, 2003 | 11:16 AM
untitled's Avatar
Old Nov 12, 2003 | 03:55 PM
trigun7469's Avatar
all buy it for the low ball price of 25 dollars
Old Nov 15, 2003 | 05:41 AM
paopao's Avatar
Default Re: Ls/Vtec motor $1000. b16 head b18a block LOW BALLER WELCOME (trigun7469)
so what exactly needs to be done to get this motor back up and running. i'm in illinois so i'd probably be interested in picking it up
Old Nov 15, 2003 | 10:47 AM
untitled's Avatar
Default Re: Ls/Vtec motor $1000. b16 head b18a block LOW BALLER WELCOME (teal91si)
you can either have machine shop grind crank for thicker bearings $90-110
OR
you can find a new std. diameter ls crank (this is what i would do so you can use OEM honda bearings)
new rod and main bearing and thrust washer set $120
so id say no more thatn $300 to put back in to get it running good.
GsrHatcher
12
Sep 2, 2024 09:11 PM
jdmbeegee
Southeast (Sales)
Jan 21, 2008 10:05 PM
tavius44
29
Oct 20, 2006 11:39 AM
hotimportcrx
Northeast (Sales)
Mar 27, 2006 06:51 PM
nodamnnamesleft
Sep 10, 2005 05:50 AM
