Balancing/Blueprinting?
Old Oct 29, 2003 | 12:41 PM
hybridreams's Avatar
Default Balancing/Blueprinting?
I've always wondered what's involved in balancing/blueprinting an engine. Can anyone educate me?
Old Oct 29, 2003 | 01:30 PM
IN VTEC's Avatar
Default Re: Balancing/Blueprinting? (hybridreams)
I'm not sure if I have the composition to fully explain what those terms mean in a short sentence, but I'll give it my best shot.
Blueprinting is optimally spec'ing out and clearancing the motor for whatever duty it's intended for the majority of its usage.
Balancing is the equalization and minimizing of opposing and secondary forces in the rotating assy.
Performance motor building is integrally tied in with machining and blueprinting/balancing. You can't do one without the other and hope to have any real understanding of how it all goes together and interrelates. Even a bit of metallurgy is very helpful.
The processes by which you go about attaining those goals is inclusive of the term "blueprinting and balancing", and is much more task- and precision-intensive than most people would tend to believe at first. Not all of the processes are absolutely necessary for every level of build and combination of parts if you already know it's not an issue, but you won't know that until you check or measure it or you take somebody else's word for it.
There's so much more to it than just 4 paragraphs and my meager thoughts on the subject...so keep studying it more.
Old Oct 29, 2003 | 02:36 PM
Ottoman's Avatar
Default Re: Balancing/Blueprinting? (IN VTEC)
soudns kinda like u're balancing and grinding away to remove as much vibration at higher roational speeds so that it doesn't wobble (micro scale of course) and such
almost the same as the balance a Turbo by grinding minute amounts away from the blades
Old Oct 29, 2003 | 02:45 PM
IN VTEC's Avatar
Default Re: Balancing/Blueprinting? (Ottoman)
You're not always grinding stuff away. Sometimes it's as simple as matching various pistons and rods from various sets to get a closely weighted set. Then, you can take off material where needed to precisely match all the masses, depending on how **** you need to be.
Same could be applied to ring end gaps. You'll wanna move them around first to get the best overall fit for all cylinders before you start filing the ends to clearance them into the bores.
Old Oct 30, 2003 | 05:23 AM
JimBlake's Avatar
Another way of saying it is that you're trying to build an engine closer to perfect than what they allow at the factory.
Say the pistons are supposed to match within 1 gram. Maybe you try to find a set that matches within 1/2 gram.
Say the bore is supposed to be straight & true within 0.001". You try to make it within 0.0004".
The numbers are bogus, I just made them up. But I'm trying to get the idea across. The actual #s you want depend on your goals for the engine. And how deep your pockets are.
Choy
23
Mar 8, 2009 11:08 AM
ef-hatchcrap
Feb 7, 2008 10:00 AM
ALLMOTORD16Z6
Aug 4, 2005 01:25 AM
willyboyK20
Nov 25, 2003 05:04 PM
E Swift
Jul 10, 2001 11:44 AM
