MY BUILT H22 SETUP
Ok here is the setup I"m going to build over the winter. Please chim in if you have any feedback that can help. And I also included in the horsepower goal also and the break down of it all. This is going to be a JDM h22 by the way. The motor is going to be kind of rebuilt
stock 160-165 whp (10.6 compression)
type-s pistons 165-170 (11.1 compression) with eagle rods
mugen headgasket 170-175 (11.4-11.5 compression)
an-r or 10-94 header 190-195
custom 2.5 exhaust 195-205
intake 205-209whp *with tuning*
This doesn't seem unresonable horespower goal does it. I will eventually put Jun cams in it after this year of college is over. Any insight or suggestion would be helpful.
Sounds like a nice setup bro, but In order to get to your goal of 205-209, you'll need a little more work.
Once you get your cams and headwork, you'll be on your way.
I don't know guys I think thats all I"m going to need to crack 200whp. It's really not that hard, just have to find the right parts to completment each other. But I know you guys know also because you already built your motor so..... will have to see.
i made 203.8whp and 158tq with just bolt ons, mild port work w/ stock cams and stock bottom end. I have yet to tune the ecu to this setup...could probably make a bit more power w/ a tuned ecu.
Well hopefully I can accomplish my goal with a street header and no port work, might i might get port work done because the guy is helping me out alot with labor prices.
Aaron.Hillman
Jun 7, 2007 05:35 PM
