Pic Request: CRX Sohc Turbos(Engine bay shots)
Old Oct 29, 2003 | 11:44 AM
Grease Monkey's Avatar
Default Pic Request: CRX Sohc Turbos(Engine bay shots)
Just as the top states. TIA!
Old Oct 29, 2003 | 01:20 PM
*Boostwerks*'s Avatar
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (Grease Monkey)
What about a CRX with a DOHC D series?...
Old Oct 29, 2003 | 01:51 PM
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (Bryson)
SOHC and DOHC D series is fine... Any more pics?
Old Oct 29, 2003 | 02:06 PM
You ask, and you shall receive... ...
Blown carbon headgasket = small carbon bits in the oil = clogged inlet to the pump = pressure at idle but all of a sudden when driving you have 0 pressure and it throws a rod...
New motor is getting built this winter.
Old Oct 29, 2003 | 02:09 PM
racinskittle's Avatar
That's an interesting oil return setup. Does that work well?
Old Oct 29, 2003 | 02:10 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">What about a CRX with a DOHC D series?...
just wnated to ***** out ur pic eh
Old Oct 29, 2003 | 02:13 PM
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">That's an interesting oil return setup. Does that work well?</TD></TR></TABLE>
well considering I only was able to drive for 35miles...It worked Great!
I seriously dont know yet how well it will work in the long run...But it is completely down hill to the pan
Old Oct 29, 2003 | 02:39 PM
B19CivicHB's Avatar
Bryson,
Is that a oil line kit from Flamenco-T? Looks real nice
-Nick-
Old Oct 29, 2003 | 02:46 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I seriously dont know yet how well it will work in the long run...But it is completely down hill to the pan</TD></TR></TABLE>
Im not sure if i like it, my opinion doesn't matter much but It's just to straight. I think the seals are going to go..........BOOM
Old Oct 29, 2003 | 03:49 PM
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (HybridcivicLS-T)
anymore pics? I'd really like to mostly see sohc....
Old Oct 29, 2003 | 04:26 PM
ghettocrxsi's Avatar
Here are a few pics of my engine bay. d16z6 for all who dont know
Old Oct 29, 2003 | 04:27 PM
D-Man's Avatar
this is a shot of my old set-up (circa 2001)
Old Oct 29, 2003 | 04:30 PM
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (ghettocrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettocrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Here are a few pics of my engine bay. d16z6 for all who dont know
Whats your setup?
Old Oct 29, 2003 | 04:31 PM
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (D-Man)
do you have anymore pics of your setup? What is your setup?
Old Oct 29, 2003 | 04:37 PM
Setup is:
d16z6 with crower 4340 cromoly rods (none of that econo crap)
9.0:1 JE pistons
Total seal rings (I think they might be leaking a bit)
Sfp log manifold
t3 .63 ex .48/ar compressor side (from a t bird)
tyrus 30x6x2.25 Intercooler
My own piping
Fmu,missing link and walbrow 255hp
Waiting on my chip burner and 550's and wideband to come in so I can use my uberdata.
Old Oct 29, 2003 | 04:43 PM
D-Man's Avatar
hmm,,well that set-up is kinda dated and im always upgrading or changing something..In the pic is a stock D16Z with a Drag Gen 2 turbo kit with T3/04b turbo,550cc injectors,zdyne gold ecu,MSD 6al and a couple of other things I forgot
BTW...those crane 11mm wires are pieces of ****,I didnt forget that....
Old Oct 29, 2003 | 08:31 PM
BoostedED9's Avatar
and hydrolocking under boost causes this....
Old Oct 30, 2003 | 05:51 AM
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (BoostedED9)
Anymore? Anyone run turbo using the HF manifold? Which is better? Did you guys have to use a missing link? Any videos?
Old Oct 30, 2003 | 06:26 AM
TravSi's Avatar
This is my 90 crx w/ 60 trim T3...made 205whp on 6psi, im in the process of building a new manifold and 2.5" down pipe
Old Oct 30, 2003 | 07:22 AM
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (RexSiT3)
did you happen to beef up to motor?
Old Oct 30, 2003 | 07:38 AM
TravSi's Avatar
My compression is 8.5:1, the engine is built with srp pistons and eagle rods... the head had a valve job and zex 59300 cam and springs, nothing that was major.....
Old Oct 30, 2003 | 08:27 AM
Happyman's Avatar
CRX del Sol? :-D
Old Oct 30, 2003 | 01:31 PM
Default Re: Pic Request: CRX Sohc Turbos(Engine bay shots) (eh6turbo)
What are the best numbers using stock internals? what is a safe amount of boost without blowing something?
Old Oct 30, 2003 | 01:58 PM
Happyman's Avatar
Boost isn't really the issue its horsepower. People have made 300+ on stock block. It's all to what extreme you want to go to.
Old Oct 30, 2003 | 02:19 PM
BoostedED9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh6turbo &raquo;</TD></TR><TR><TD CLASS="quote">Boost isn't really the issue its horsepower. People have made 300+ on stock block. It's all to what extreme you want to go to.</TD></TR></TABLE>
i have gone 302hp sae corrected, i have never heard of anyone else going that highw ith a stock block and head... oh yea, if you notice i was also runing the a6 intake manifold/tb instead of the z6 so im thinking that was a small restriction....
