help ASAP! what size hex? how many crush washers for brake lines?
Old Oct 29, 2003 | 10:25 AM
euclid's Avatar
Default help ASAP! what size hex? how many crush washers for brake lines?
i need this info this afternoon if possible...
the banjo bolt connecting the brake linnes to calipers use crush washers. do i need one washer for each side of the brake line(2 per caliper) or only one washer per caliper? if the answer is only 1 then where does it go, touching the caliper and brake line, or touching the brake line and banjo bolt head?
also, for steering wheel removal, what size hex head driver do i use for the large hex bolt holding the airbag... T-?
the last time i did this i was at my parents house, my dad has a full set of hex drivers, i unfortunately do not and i need to buy the correct size today.
please help, thanks
Modified by euclid at 3:40 PM 10/29/2003
Old Oct 29, 2003 | 10:42 AM
euclid's Avatar
Default Re: help ASAP! what size hex? how many crush washers for brake lines? (euclid)
the torx head is a T-30.
2 washers are needed per caliper, one on each side of the banjo bolt.
edit: the hex head is actually called a Torx head, hence the T-30
Modified by euclid at 4:03 PM 10/29/2003
Old Oct 29, 2003 | 10:48 AM
King Tut33's Avatar
17 minutes and you were able to find your own answer. Nice work.
Old Jan 29, 2021 | 09:31 AM
Nico Dee's Avatar
What size ID for the crush washers do you use?
R-gonaut
Jun 5, 2011 07:27 PM
theeogflip
Nov 8, 2009 10:45 AM
Filliam H. Muffman
Sep 13, 2006 09:38 AM
euclid
Oct 29, 2003 10:39 AM
