Which Throttle Body
Old Oct 29, 2003 | 07:25 AM
Grease Monkey's Avatar
Default Which Throttle Body
Which throttle body can I use on a CRX Si Manifold... B-series wise. Its it a direct bolt on? What kind of gain will I get. TIA!
Old Oct 29, 2003 | 08:26 AM
warrick's Avatar
Default Re: Which Throttle Body (Grease Monkey)
from my own experience, the throttle body from a 96 integra LS (b18b? b18a?) does NOT bolt right on. three bolts don't quite line up, and the fourth is nowhere near.
I'm guessing older b-series if any...
Old Oct 29, 2003 | 08:48 AM
Redline130's Avatar
Default Re: Which Throttle Body (warric_k)
No B-series T/B will bolt up to the A6 manifold. Any 92-up D-series manifold will fit a B-series T/B though.
Old Oct 29, 2003 | 09:57 AM
Waachback's Avatar
Default Re: Which Throttle Body (Redline130)
hmm. I have a friend with a b18c1 TB on his D16z6.......
Old Oct 29, 2003 | 09:59 AM
Default Re: Which Throttle Body (Waachback)
yea but he says it will not fix A6 manifolds... maybe you confused it with a Z6?
Old Oct 29, 2003 | 10:02 AM
Waachback's Avatar
lol no im not i was just saying that it does fit most d series manifolds......
Old Oct 29, 2003 | 10:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">No B-series T/B will bolt up to the A6 manifold. Any 92-up D-series manifold will fit a B-series T/B though.</TD></TR></TABLE>
Old Oct 29, 2003 | 10:09 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote"> <U>No B-series T/B will bolt up to the A6 manifold</U> . Any 92-up D-series manifold will fit a B-series T/B though .</TD></TR></TABLE>
If you notice he says 92 and up they will fit on which is what a d16z6 is. You will not get a b-series tb to fit onto an A6 without some major modifactions or maybe a plate to convert the holes to different positions??
*EDIT* Damn slow comp...lol...GreaseMonkey beat me to it
Old Oct 29, 2003 | 10:19 AM
-16V-'s Avatar
Default Re: Which Throttle Body (Vinceg99)
I tought i saw something like that in the honda tuning magazine where they were doing that budget boost ****.And if i was not mistaken it was a ls t/b on a z6 intake manifold.
could be wrong tho.
Old Oct 29, 2003 | 10:28 AM
Vinceg99's Avatar
Default Re: Which Throttle Body (1991_jdm_sleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991_jdm_sleeper &raquo;</TD></TR><TR><TD CLASS="quote">I tought i saw something like that in the honda tuning magazine where they were doing that budget boost ****.And if i was not mistaken it was a ls t/b on a z6 intake manifold.
could be wrong tho.</TD></TR></TABLE>
Whats so different about that? Again B-series will fit on 92 and up IM's. And a d16z6 is from a 92-95 so yeah the LS TB will bolt right on.
Old Oct 29, 2003 | 10:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">
Whats so different about that? Again B-series will fit on 92 and up IM's. And a d16z6 is from a 92-95 so yeah the LS TB will bolt right on.</TD></TR></TABLE>
Exactly
Old Oct 29, 2003 | 11:31 AM
89a6T's Avatar
whats the difference ? the size of the butterfly? and could i just have the butterfly off a ls machined into a a6 t/b?
Old Oct 29, 2003 | 12:44 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: (89a6T)
The difference is the bolt pattern. you know, the bolts you use to attach it to the manifold. And also the internal size of the T/B.
if you want a bigger throttle body, then click on this link.
https://honda-tech.com/zerothread?id=598639
Old Oct 29, 2003 | 12:46 PM
Malgerus's Avatar
Default Re: (The new Spaceballs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs &raquo;</TD></TR><TR><TD CLASS="quote">The difference is the bolt pattern. you know, the bolts you use to attach it to the manifold. And also the internal size of the T/B.
https://honda-tech.com/zerothread?id=598639 </TD></TR></TABLE>
That looks sweet! I might be sending one over your way in the winter
NA_95
Jul 20, 2009 05:39 AM
ProjetEF
Jan 25, 2008 05:15 AM
onesikdb8
Apr 13, 2007 01:53 PM
DCSportEJ1Civic
Oct 24, 2006 08:43 PM
theinfamouskonrad
Apr 10, 2005 05:24 PM
