Is there any easier way to read the timing marks??
Old Sep 5, 2001 | 03:47 PM
93B18's Avatar
Default Is there any easier way to read the timing marks??
It's really hard to advance or retard timing when it's so hard to see the marks on the pulley with a timing light! Do you guys have any tips or suggestions on reading the timing marks better? Any help is greatly appreciated. Thanks.
Old Sep 5, 2001 | 05:00 PM
fixhondas's Avatar
Default Re: Is there any easier way to read the timing marks?? (93B18)
put some white paint (paint marker) on them
Old Sep 5, 2001 | 05:19 PM
coquinn's Avatar
You do have the clip installed in the ECU jumper, correct? If not, the ECU will make the timing marks jump around because it's constantly compensating. Make sure you're following the correct procedure ...the mark should stay remotely steady.
jesshaines
10
Aug 14, 2017 04:31 AM
danteisme
Apr 26, 2017 09:24 AM
dem0nk1d
Jun 27, 2012 12:39 PM
1mistashank
May 29, 2009 08:17 PM
EGHatchy
Jul 28, 2002 05:07 PM
