IB Spec Super Dupers Wiseco Pistons
Old Oct 29, 2003 | 12:38 AM
jeremy.'s Avatar
Default IB Spec Super Dupers Wiseco Pistons
can anyone post their opinions on these pistons?
Old Oct 29, 2003 | 07:48 AM
AllMotorMadness's Avatar
Default Re: IB Spec Super Dupers Wiseco Pistons (ek_jeremy)
IB Spec Pistons you can't go wrong. It has been proven on the track and dyno!
Old Oct 29, 2003 | 08:08 AM
genius's Avatar
i've seen couple make over 260 and a ton at around 250.
Old Oct 29, 2003 | 09:00 AM
JMendez's Avatar
i guess i may be mistaken but I thought the super dupers were CP pistons?
Old Oct 29, 2003 | 09:02 AM
TodaSi's Avatar
Default Re: IB Spec Super Dupers Wiseco Pistons (JMendez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMendez &raquo;</TD></TR><TR><TD CLASS="quote">i guess i may be mistaken but I thought the super dupers were CP pistons?</TD></TR></TABLE>
No, those are the "Ultimates", IB Wiseco's are "Super Duper"
Old Oct 29, 2003 | 09:26 AM
MaxBoost's Avatar
New User
Default Re: IB Spec Super Dupers Wiseco Pistons (TodaSi)
I have some super dupers, and my motors goal is around 230-240whp, they are very light and have gas ports to help seal the rings..
Old Oct 29, 2003 | 09:32 AM
vtecvoodoo's Avatar
Future Texas Boy
Throwing a set in a motor this weekend
Old Oct 29, 2003 | 11:29 AM
RedZone's Avatar
Default Re: IB Spec Super Dupers Wiseco Pistons (vtecvoodoo)
We made 260 with 175lbs with the IBSpec SuperDupers and long rod combo
Old Oct 29, 2003 | 04:18 PM
gsrvx's Avatar
New User
Todd (b19coupe) made 259whp on the dyno recently.
85mm Super Dupers.
ROd
Old Oct 29, 2003 | 04:36 PM
A D NOH's Avatar
I really don't know
Community Builder
Default Re: IB Spec Super Dupers Wiseco Pistons (ibspecHATCH)
when is ROD going to make 259whp?
Old Oct 29, 2003 | 04:57 PM
gsrvx's Avatar
New User
Default Re: IB Spec Super Dupers Wiseco Pistons (JDM EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EK9 &raquo;</TD></TR><TR><TD CLASS="quote">when is ROD going to make 259whp?
When Rod has another daily driver haha
Old Oct 29, 2003 | 05:12 PM
genius's Avatar
when Rod grows some *****
Old Oct 29, 2003 | 05:52 PM
TREVER's Avatar
Default Re: IB Spec Super Dupers Wiseco Pistons (genius)
Screw Ib super dupers buy endyn rollerwaves they have a better name . Who needs proof anyway?
Old Oct 29, 2003 | 05:55 PM
gsrvx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genius &raquo;</TD></TR><TR><TD CLASS="quote">
when Rod grows some ***** </TD></TR></TABLE>
Old Oct 29, 2003 | 07:40 PM
omega11855's Avatar
Super Dupers Are the Bomb the only way to go IMHO
Old Oct 29, 2003 | 07:53 PM
eviltwin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibspecHATCH &raquo;</TD></TR><TR><TD CLASS="quote">Todd (b19coupe) made 259whp on the dyno recently.
85mm Super Dupers.
ROd</TD></TR></TABLE>
what kind of setp-up is that?
Old Oct 29, 2003 | 08:24 PM
gsrvx's Avatar
New User
Default Re: IB Spec Super Dupers Wiseco Pistons (eviltwin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eviltwin &raquo;</TD></TR><TR><TD CLASS="quote">
what kind of setp-up is that? </TD></TR></TABLE>
85mm Super Dupers 13.5:1
GSR crank
Toda Ds
ITR head (ported/welded chambers)
Hytech Header
Full exhaust (i think typeR piping/muffler)
ITR IM
Hondata
Old Oct 29, 2003 | 08:57 PM
omega11855's Avatar
Rod i heard you ran mid 13's in the hatch congrats for relativley stock motor
Old Oct 29, 2003 | 09:29 PM
SashK's Avatar
Default Re: (omega11855)
IB super dupers are unreal, proven power
Old Oct 30, 2003 | 06:41 AM
igotyofire's Avatar
Default Re: (SashK)
iono i think any motor can make power with a 13.5:1 compression,heh anyone know about the ib spec wiseco, not the super dupers? , super dupers have to high of a compression to daily drive around in cali
Old Oct 30, 2003 | 07:38 AM
Suprdave's Avatar
Default Re: (igotyofire)
Aren't Super Dupers the only shelf pistons with an 8cc Dome?
Old Oct 30, 2003 | 08:33 AM
2point6's Avatar
Default Re: IB Spec Super Dupers Wiseco Pistons (InnovativeHP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InnovativeHP &raquo;</TD></TR><TR><TD CLASS="quote">Also, if you compare motors with very similar set ups running a different piston they tend to make Less power than motors with the IB Spec pistons. Others are in the 230-240'ish range and it seems the IB pistoned motors are hitting in the 250-260+ range.
Modified by InnovativeHP at 5:15 PM 10/29/2003</TD></TR></TABLE>
If the engines are similar (everything the same except for the pistons) how can the gains be that much higher? I am not down on IB at all, I am actually impressed with their stuff, but something doesn't make sense to me here... If the stroke, bore, compression, bearing clearances, ring gaps, fuel tuning...etc are all identicle, how can their be a difference in power by just changing a JE piston to a IB piston? Is there more to the comparison? Are the engines really that identicle or is there some "magic" or "voodoo" involved? I would like a reasonable explanation to these questions. I think "heresay" is one thing... I could tell you my "magic" pistons make even more power than say the next, but I had better be able to back up the claim. If there were differences in the engine set-ups then the comparison and gains of 10-20 WHP can't be valid, based on "just the pistons alone".
Old Oct 30, 2003 | 03:34 PM
TREVER's Avatar
Default Re: IB Spec Super Dupers Wiseco Pistons (2point6)
weight
skirt
dome
rings
gas ports
Old Oct 30, 2003 | 04:44 PM
Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote"> anyone know about the ib spec wiseco, not the super dupers? </TD></TR></TABLE>
what he said. i'm interested in possibly the 11.8:1 or 12.8:1's on an occassionally street driven car on 92+ pump gas.
Old Oct 31, 2003 | 01:11 AM
speedyonez's Avatar
They have the dyno charts to prove what the IB spec's can do... but uhmmm i dont see how a different brand piston in the same motors would make such a difference...
