Anyone have a CTR REAR sway bar on an EK?
Old Oct 28, 2003 | 08:04 PM
Fowler.'s Avatar
Default Anyone have a CTR REAR sway bar on an EK?
I'm just wondering how I'm going to mount this... as far as a subframe reinforcement kit.
Beaks will work, but I think it's going to push the bar out too far. Anyone use the Beaks kit without the spacer (between the d-bracket and subframe)?
fyi, CTR rear bar and ITR rear bar are shaped different.
And I know Mugen has a kit, but I'm not sure if i want to spend the $$$ on that.
Old Oct 28, 2003 | 09:25 PM
Fowler.'s Avatar
Default Re: Anyone have a CTR REAR sway bar on an EK? (Fowler)
Old Oct 28, 2003 | 09:30 PM
ATS*Mark's Avatar
OG triple OG
i didnt know ctr and itr were shaped different , theres another subframe reinforcement kit on the market i forgot who makes it...
Old Oct 28, 2003 | 09:33 PM
The Internet Tough Guy's Avatar
Default Re: Anyone have a CTR REAR sway bar on an EK? (Hella_JDM)
bsq is the other one.
Old Oct 28, 2003 | 09:36 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Anyone have a CTR REAR sway bar on an EK? (jwn7)
thank you , that ones alot thinner , you might have better luck with that fowler
Old Oct 28, 2003 | 09:41 PM
Fowler.'s Avatar
The difference between the two bars is how far the enlinks are pushed out... which is why there is a spacer on the beaks kit. To compensate for that. With the ctr bar, it sits more flush with the subframe. So, in order to run it, I'm going to need to mount the d-brackets directly to the frame and have half beaks kit on the other side. Make sense?
So, I'm not sure if the bsq kit is going to make much of a difference in that respect..
Old Oct 28, 2003 | 09:53 PM
Fowler.'s Avatar
here are some pics to compare..
CTR:
Old Jul 25, 2004 | 04:53 PM
ek9vboi2's Avatar
Default Re: Anyone have a CTR REAR sway bar on an EK? (Fowler.)
back from the dead!
wow...i just learned something new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fowler. &raquo;</TD></TR><TR><TD CLASS="quote">The difference between the two bars is how far the enlinks are pushed out... which is why there is a spacer on the beaks kit. To compensate for that. With the ctr bar, it sits more flush with the subframe.</TD></TR></TABLE>
when i was doing some research on itr and ctr sway bar,,,i noticed the same thing when i looked at my sway bar (CTR) and ITR sway bars...like on beaks's website.
I will take some more pics along with a "BSQ" kit for EKs and post them. I just wanted to know if want fowler. says is true.
after all, it needs reinforcement in the back part of the subframe, not the front right???
Old Jul 25, 2004 | 04:54 PM
ek9vboi2's Avatar
also, to add... i would like to know if you (fowler.) evern installed the bar and how you did it.
Old Jul 25, 2004 | 04:59 PM
chad's Avatar
Moderator
i have an ITR rear sway bar on my EM1
Old Jul 25, 2004 | 07:30 PM
ek9vboi2's Avatar
anyone else?
Kennyjai
Jun 22, 2012 09:36 AM
Naterror
Suspension & Brakes
Sep 2, 2006 11:53 AM
saveacivic
Suspension & Brakes
Apr 15, 2006 12:31 AM
klomast3r
Nov 5, 2005 04:08 PM
poop32145432
27
Feb 1, 2004 09:18 AM
