I NEED UR ADVICE!
Old Oct 28, 2003 | 07:56 PM
tofast4u's Avatar
Default I NEED UR ADVICE!
i just recently bought a 94 civic coupe. its the dx peice with the slow as crap motor. i want to do a swap but i dont have a ton of money for a gsr or anything to high end. what would u recomend? also exhuast and intake wise what is the best performing parts for the car. i am in the process of redoing everything and i wanted u alls oppinions. any pics of cars like what im talking about please let me see. thanks a lot guys.
p.s. if any body has anyhting for sell let me know cuz im probably really interested in buying .
Old Oct 28, 2003 | 08:04 PM
The Internet Tough Guy's Avatar
Default Re: I NEED UR ADVICE! (tofast4u)
first, click the search button and do a bunch of searches that are not very specific.
second, i would suggest you get a used d16z6 or d16y8 for around 500 bucks and go turbo. sohc turbo is the way to go if your on a budget.
or just be slow for awhile and save your money for a good turbo setup or a swap.
Old Oct 28, 2003 | 08:05 PM
Archidictus's Avatar
Unceasing Measure
Save your money and write up a detailed plan so you don't end up spending money on things you won't need/want later. A good steering wheel, shift **** and seats will make any car a helluva lot better. Suspension work makes your car more fun to drive (when done correctly), ignition upgrades can be moved over to a swap (MSD stuff), as well as a nice exhaust system.
Wheels and good tires, sound systems, fuel system mods, etc. Don't get in a hurry: that's what causes the most problems.
skribblah's Avatar
got the same car. just its 93. this is what i have done so far and what my plans are:
RSR springs & ITR shocks with ITR LCA's - GET THESE!!! they are the best combo i have found to date! ride is solid!!!
and for engine, if i could go back, i would save up for a cheep b16 swap, and chill with that for a while, then buy an ls block and abuch of other **** and go ls/vtec.
Old Oct 28, 2003 | 08:09 PM
tofast4u's Avatar
Default Re: I NEED UR ADVICE! (skribblah)
with the suspension i was wanted to go with kyb agx fully adjustable and probably eiboch coil over fully adjustable. with the motor i wanted to go b 16 or ls but ive heard with redoing the internals u can make a sohc vtec really quick.
Old Oct 28, 2003 | 08:10 PM
Default Re: I NEED UR ADVICE! (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote"> Don't get in a hurry: that's what causes the most problems.</TD></TR></TABLE>
exactly. take your time and save your money. figure out what you want out of your car (drag, autox, show, street, etc). then make a good plan to get there and a sheet that lists everything you will need. logically prioritize your mods so you dont have a car that runs 11's but cant stop for ****.
patience is key - dont learn the hard way like most have.
chatman_55
Feb 8, 2009 10:54 PM
laxbuddy48
Aug 14, 2007 12:30 PM
skater5067
Jan 31, 2005 03:34 AM
out_of_order
23
Mar 10, 2004 10:38 PM
HonduhEx
21
Feb 13, 2003 11:31 AM
