Piston and Rod quest
What OEM piston and rod combo would be the best for a B16. I was thinking CTR pistons and rods. cause i have the ITR head. Any suggestions? Im hoping to break 200 WHP. B16 block stock internals, STR fuel Rail, Holley FPR set at 55psi at WOT, MSD Digital 6 plus ignition with MSD blaster coil, B16 Intake Mani, AEM cam Gears. Just Ordered UR Racing Crank pulley, AN-R header and Fields Vtec Controller.
i agree B16B does have a taller block. What cams are you running and why are you running a b16A manifold. Go ITR/CTR or something else. You are restricting the flow of your motor.
