y8 swap need coolant help
Old Oct 28, 2003 | 04:56 PM
mini-cRx's Avatar
Default y8 swap need coolant help
i put a 98 y8 in my 88 civic lx and the tempeture goes up when i am stopped to long i thing i need to do something with a colant sensor please help thanks
Old Oct 28, 2003 | 05:33 PM
Redline130's Avatar
Default Re: y8 swap need coolant help (mini-cRx)
Does your fan turn on?
Old Oct 28, 2003 | 06:02 PM
mini-cRx's Avatar
Default Re: y8 swap need coolant help (Redline130)
no it doesnt
Old Oct 28, 2003 | 06:03 PM
revhigh89's Avatar
make ur own switch, so u can turn the fan on manually with a switch from inside....
Old Oct 28, 2003 | 06:06 PM
mini-cRx's Avatar
Default Re: y8 swap need coolant help (evilryu530)
i need to know how to put the coolant sensor on the motor
Old Oct 28, 2003 | 06:13 PM
USDM 4G VTEC's Avatar
dont do the Y8 have the plug on the back of the block like the Z6??? and u can swap termoswitches....
Old Oct 28, 2003 | 06:20 PM
mini-cRx's Avatar
Default Re: y8 swap need coolant help (USDM 4G VTEC)
why would i swap thermoswitchs and the plug hole was bigger than the size of the two prong coolant sensor
Old Oct 28, 2003 | 06:31 PM
Redline130's Avatar
I'm getting confused on this.....where is this two prong coolant sensor located, and where and why are you trying to swap it?
Are you talking about the ECT sensor? The one located on the side of the head?
Old Oct 28, 2003 | 07:24 PM
mini-cRx's Avatar
no the coolant sensor that is in the back of the block
Old Oct 28, 2003 | 10:47 PM
fourthgenhatchB17's Avatar
the coolant sensor has moved to the thermo housing on that Y8 block of yours. Just extend the wires from the back of the block (where they are right now, because i know u transfered over the old engine harness to the Y8) and plug them in on the sensor on the thermostat housing. Then your fan should turn on.
Old Oct 29, 2003 | 12:46 AM
7PSI CRX's Avatar
Default Re: y8 swap need coolant help (fourthgenhatchB17)
Like he said above.
You need to get the plug that fits the conector on your Y8 thermostat housing, and hook up your old 2 radiator fan wires to the plug you get (at a junkyard),
and all will be good.
Old Oct 29, 2003 | 09:36 AM
mini-cRx's Avatar
Default Re: y8 swap need coolant help (7PSI CRX)
so do i hook up the fan wires and or the old plug from the back
Old Oct 29, 2003 | 12:06 PM
7PSI CRX's Avatar
Cut the connectors off of your old radiator fan switch wires (the back of the engine) and extend those 2 wires and attach them to the new plug you get from the junkyard. (That fits onto the Y8 thermostat housings thermosensor)
Ge-money
Mar 16, 2013 10:25 AM
gnar kill
Nov 24, 2005 09:24 AM
mr. carpenter
Apr 10, 2005 08:39 AM
phatrick2332
16
Sep 4, 2003 07:48 PM
shorty91
12
Aug 25, 2003 08:29 PM
