What size injectors for my setup??
First off, do bigger injectors really help out and make noticeable difference?
You can check out what my GS-R has if you click on my sig.
What size injectors would you recommend with my setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR »</TD></TR><TR><TD CLASS="quote">First off, do bigger injectors really help out and make noticeable difference?
What size injectors would you recommend with my setup?</TD></TR></TABLE>
at least list your mods, lazy.
Don`t make us follow a link
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">
Don`t make us follow a link</TD></TR></TABLE>
Me? Lazy? Hell yes.
But seems like you're lazy as well. All you need to do is click.
Current Mods:
- Skunk2 Stage 1 Cams
- Skunk2 Cam Gears
- Skunk2 Intake Manifold
- ITR AEM CAI
- DC 4-1 header
- Tanabe Super Hyper Medallion Exhaust
- Apex'i VAFC
- B&M Fuel Pressure Regulator
- Fugen Front / Rear Strut bars
- Razo Shift **** / pedals
- H&R Sports springs
- OEM Kit
Mods waiting to be installed:
- Skunk2 Valvesprings
- Skunk2 Ti-Retainers
- Skunk2 OBD2-1 Harness
- chipped p28 ecu
- AEM Tru-Power Pulley kit
Future Mods:
- DTR header
Me? Lazy? Hell yes.
Current Mods:
- Skunk2 Cam Gears
- ITR AEM CAI
- DC 4-1 header
- Apex'i VAFC
- OEM Kit
- chipped p28 ecu
Future Mods:
- DTR header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">go 310`s just in case you go bigger down the road.</TD></TR></TABLE>
Sounds good to me....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">go 310`s just incase you go bigger down the road.</TD></TR></TABLE>
I'm close to maxing out the 290's in my stock cam, stock bottom end, stock head itr...the 310's will give you some more room, a bigger cam would most likely like a larger injector.
Austin
I'm close to maxing out the 290's in my stock cam, stock bottom end, stock head itr...the 310's will give you some more room, a bigger cam would most likely like a larger injector.Austin
See Are X
Dec 14, 2005 07:29 AM
